Results 1 to 11 of 11
Thread: Bleeding ABS Brake System
    Default Bleeding ABS Brake System
    I have bled the whole system 3 times and there are no leaks or air in lines, but I have NO brakes whatsoever. There must be a certain order which you have to bleed the ABS unit and the wheels or something. Not a big deal yet I'll probably figure it out later, just wondering if there is something major I'm leaving out...
    ATL, GA
    Quote Originally Posted by BIG WORM
    I bled my brakes a few weeks ago, and I didn't have touch the abs system at all. I even kept all the wheels on my car, there are several write ups about bleeding brakes online so I won't go into detail, but you must have messed up somewhere. And yes, you bleed the brakes in a certain order, and don't let the master cylinder get too low on fluid. Go buy a Haynes book for your car. Best $15 I've spent towards my car. Good luck.
    Yeah man. Fr33way's Avatar
    North OTP
    You start from the farthest caliper away from the MC and get closer each time.
    Crash
    Snellville, GA
    you could have a ****ed up master cylinder
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    JDM TYTE AnthonyF's Avatar
    FIRST OFF-are you doing this with a friend or by yourself?
    You might have drained out too much at a time and didnt refill it fast enough.
    Bleed out the master cylinder...Get one person in the car, one person with a wrench on the master cylinder. Bleed each line quite a few time and make sure you keep filling the reservoir. If that doesnt fix it, your master cylinder could be bad.
    -Ant.
    The Carbon Fibered R6
    Yea I have so many Haynes and Chilton manuals, I am just so impatient with them that I usually just eventually figure stuff out after I lose my mind in frustration with those books. Thank God I bled those brakes 4 times before I thought to replace the master cylinder because then I got to bleed them 3 more times and that makes 7 times all the way around the same car. I think thats one for the Guiness book.
    94 and 95 integras have a bleeder valve on the abs anyone know what to do with it?
    Wheres the money?
    McDonough
    check all the soft brake lines make sure the brake fluid is not contaminated.
    Suwanee, GA
    I don't know about other ABS units, but on the IS you have to pressurize the system to about 14.7psi to bleed the abs you can't pedal bleed it.
    Hwy 315
    ^ it is the same with DC ABS brakes.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    how do i build the pressure up other than pumping the pedal? The pressure goes up way past 14psi when you crank it up and the hydraulic modulator comes on.
