Results 1 to 14 of 14
Thread: A/C wont work! HELP!!!!
    Hear me YET!!! civ97's Avatar
    Woodstock
    Default A/C wont work! HELP!!!!
    So I have narrowed it down to a wiring problem I think.
    I've searched up and down the harness and cant find any cut wires, nothing seems to be grounded anywhere it's not susposed to be.
    My condensor fan won't come on but when I tested it on a relay it works fine. Could it be the connection?
    Any suggestions? And I'm willing to re-test everything so any ideas at all compressor, wiring, fan, condensor, etc.
    Crash
    Snellville, GA
    is the CEL coming on?
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    Crash
    Snellville, GA
    did you check your fuse?
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    Woodstock
    Fuse is blown but every time i replace the fuse it just blows again.
    Jay_Bird JayL's Avatar
    McDonough, Ga
    check your relays and make sure they dont have water in them
    Woodstock
    No my CEL isn't on. But I'll recheck my relays. Anything else you can think of?
    Crash
    Snellville, GA
    you might want to test the thermo switch (and also pressure switch)
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    Crash
    Snellville, GA
    Also you can take apart the 2 AC relays connected to the condenser fan.
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    Crash
    Snellville, GA
    Check them to see if theyre fried or there could also be oil in them
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    McDonough, Ga
    Quote Originally Posted by suprapower
    these are the 2 relays i mentioned. they are notorious for going bad from water/oil in them.
    Woodstock
    that would cause the fuse to blow, just water or oil in the relay?
    Crash
    Snellville, GA
    it could be otth i believe not too sure on that
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    Senior Member G.C's Avatar
    Forgot
    you might have a short somewhere.
    :idb:
    Woodstock
    Thanks guys! Ill check it out and let ya know how it goes. REPS
