Have a deal on the table.....sorry guys
soooo. want my siezed 14bOriginally Posted by highspeed
No really, I'm looking to get rid of the wheels and the eibachs/AGXs off the eclipse (going for stock suspension for squatting and 2g chromes). What does this need to be bolted up to my car?
that would be awsome but I need 5 lug hubs to do that......sorryOriginally Posted by cgEvan
I have am evo 3 very little play I'll throw in the j pipe too just need a new hot side on bolt has the cast curse and one of the threads stripped havent had a big issue with it leaking also have an evo 3 02 housing I can put in with it if you want. Do you have pics of the turbo? also my turbo has the stainless steel line. Let me know cars down so I can take it off tomorrow if needed to!!!!
4 Cylinders
3 Diamonds
2 Liters
1 Turbo
0 compromises
Is it a t3 or tdo4 housing?
4 Cylinders
3 Diamonds
2 Liters
1 Turbo
0 compromises
Also Is it Internally or externally gated? Because If its externally I can include the whole setup I'm running I have a evo 3 exhaust manifold and a 3" o2 housing with wastegate dump or the evo 3 housing. Then you can put some money on top of it I'll even throw in the 650s because I'll have to go bigger. Just let me know if your interested I can take pictures of everything.
4 Cylinders
3 Diamonds
2 Liters
1 Turbo
0 compromises
The turbo has a dsm flange and internally wastegated. I might be interested in that trade. I already have an aftermarket 3in o2 housing and down pipe. Does your car had balance shaft delete.....because I have a 3an line that Precision said to use if oil pressure is above 80lbs. Send me pix..... what kind of psi do you see daily. I only run 10lbs and i rarely go over 4k rpms....lmk
I have a less than 100 miles old(installed on 1102/2000 last weekend) Fully ported slowboy evo 3 big 16g with match ported o2 housing, stainless lines. I paid $779 for listed above + bnib evo3 manifold. lmk.
2008 Scion xD (38mpg ftw!)
2005 Chevy 1500(For towing)
1991 5.0 lx(45,xxx original miles)
2000 DB8 GS-R ( Built and SOLD)
2001 Crown Vic(61,xxx original miles)
1997 Honda Accord Ex(sold)
1995 Nissan 240sx/se(Sold)
1995 Toyota Tercel(4EFTE Swapped)(Sold)
1991 VR4 1102/2000(Sold)
To be honest since I've put it on The car hasn't seen much action when I got it from my buddy it had 2000 in it and I've maybe put 1000 on it tops. I only run 10 Boost controller hasnt worked lately and have been to busy to fix it. I drive conservatively with gas prices the way they are. I'll throw in the 650s if you want because if I go bigger I'm going to want to get a little bigger injectors. Still have the balance shafts but when I'm rebuilding I'm taking them out. I can send you the evo 3 manifold too If your interested!! trying t to make it a fair trade. I'll take it off tonight and take pics for ya. Like I said before I'll throw in the j pipe as well with is like 80 bucks on slowboy I bought it with the sbr front mount kit and I obviously won't need it. I'll try to put pics up asap I have to go to work till about 8 and i've been putting a new engine in a friend wrx so havent had much time.
4 Cylinders
3 Diamonds
2 Liters
1 Turbo
0 compromises
i will vouch for this f00! the turbo is in really good condition... its been running low boost since i can't remember when and still pulls extremely hard! bump for zachery mcboosted talon.
aww why thank you jm I can tell its slow at work haha
4 Cylinders
3 Diamonds
2 Liters
1 Turbo
0 compromises
As you can see in the pictures the back right one is the one I was talking about that is broken off also the front right one is a little stetchy on the threads but I haven't had a problem with it leaking. I'll even throw in the manifold to turbo bolts as well they are the stainless steel kit from slowboy let me know can take it off tonight and have it shipped out monday let me know also I will pay for shipping of both if you want.
4 Cylinders
3 Diamonds
2 Liters
1 Turbo
0 compromises
call me 706-429-3817...........you drive a hard bargain
Got a deal locked in with the man.Have a 20g waiting on him.
Turbo is boxed up waiting on the pm from you highspeed...
4 Cylinders
3 Diamonds
2 Liters
1 Turbo
0 compromises
Why bump?
why you bumping am i shipping this stuff out tomorrow for nothing or are we still doing the deal ? im kinda confused ?
4 Cylinders
3 Diamonds
2 Liters
1 Turbo
0 compromises
bumpin.......is like second nature.....not trying to get anymore people to call me so I will take my number off and everything
