Thread: FS: Car Audio Gear
    Cumming, GA
    Default FS: Car Audio Gear
    I have the following items available out of the Eclipse.
    Four (4) Diamond Audio D7152 Amps (2 x150) The heatsinks were taken apart, and painted burgundy to match the car. The end plates were polished. I do not have the original boxes or manuals. If you do not know what these amps are, they are probably not for you. The original cost was about $800 each. I am asking $250 each, or $900 for all 4.
    Next is four (4) Diamond Audio D610D4 Subs. The are 10: subs that are dual 4-Ohm voice coils. There were mounted inverted in the car, and were only used for SPL purposes. Honeslty, they have been played for about 15 minutes TOTAL. The rubber gasketing around the basket edge was cut to make a flat mounting surface for the inverted mounting. This does not effect performance. Again, I have four. Asking $100 each
    Next is a Diamond Audio D610D2 Sub. This was the main Sound Quality sub in there car. The aluminum cone has a few small dings in it, but again, performance is not compromised. Asking $80.
    Next is a set of MTX Component speakers. These are brand new in the box. They have never been installed or used. The only time they have been taken out of the box, was to take the pictures. They are a 5.25" system, that can bu used as a component set (seperates) or as coaxial speakers. Asking $100
    Next is a Diamond Audio Hex 5.25 component set. These were taken from the previous install in the Eclipse. They use the silk tweeters. The crossovers the red LED's installed, that you can wire up if you choose, but do not ahve to. I do not have the box, manual, or grills for the speakers. Asking $150.
    I have four (4) Hooker Audio 1-farad capacitors. These are brand new, and have never been out of the packaging. Asking $50 each.
    (ONLY the capacitors in the picture are available)
    I can be reached at [email protected] or 678-794-3697. All items are located in Cumming, GA. I will ship, but at the buyer's expense.
    JDM TYTE AnthonyF's Avatar
    wow, very nice stuff, nice listing too. Good luck homey! If I had the money i'd pick up a capacitor.
    -Ant.
    The Carbon Fibered R6
    Jan 2003
    Class A gear and Class A guy.
    Free bump.
    Ive never lost!!!!
    Loganville
    you up for trades???????
    Rude Lude Dude w/S2K JayKnight's Avatar
    NW GA...Ringgold !
    NIce to see some quality stuff for sale on IA. I Was getting scared of all the swap meet stuff some people try to pass off as great gear.
    Here is a free bump for you. Good Luck with sale.
    Later !!!
    Cumming, GA
    Thanks guys! I have more gear to list later too:
    3 Polk Audio 8" subs $100 for all 3
    3 Polk Audio 12" subs $60 each, or $150 for all 3
    3 US Amps 50HC Amps. These are circa 1998. Silver chasis. These amps are not exactly "production"... If anyone is interested, I will explain. I also have a 3-way crossover, which has also been modified (to change the crossover points) All 3 amps and Crossover for $600 as a package.
    Regarding Trades: not too much that I am looking for that most might have "laying around"....
    blank
    nowhere
    i can vouch for this stuff and guy.
    Cumming, GA
    Cumming, GA
    ttt
    ______________
    Do you still have the polk stuff for sale??
    Cumming, GA
    Yes, the Polk stuff is still available.
    Cumming, GA
    ttt
