Results 1 to 36 of 36
Thread: F*ck the GTO and Corvette
    Default F*ck the GTO and Corvette
    That is right F*ck the GTO and Corvette. I would much rather have the new Pontiac G8 GXP LS3 400hp, 6 speed, 4 door(insurance cheaper), AND IT LOOKS BETTER.
    http://www.motortrend.com/features/a...ook/index.html
    Quote Originally Posted by Motortrend
    This isn't your grandfather's Wide-Track Pontiac Ventura. It's far from your older brother's Widely Cladded Bonneville GXP. The only exterior visuals betraying the Corvette 6.2-liter, 402-horsepower LS3 V-8 under its hood are the new front fascia with big foglamps, 19-inch wheels, new rear diffuser, two badges on the side, and one on the decklid. Pontiac considered a kid-racer rear wing and replaced it with the GT's lip spoiler at the last minute. Who had the good taste to make that change?
    "Bob Lutz," says Brian Shipman, G8 product manager.
    "I agree with his approach," Shipman continues, as if he'd have a choice. "He wanted a more refined approach, and he said, 'How many BMWs do you see driving around with a wing spoiler?'"
    Before GM vice chairman and car guru Lutz arrived, the "Excitement Division" measured said excitement by how much cladding and "performance" spoilers it could trowel onto a car. Lutz ordered all that stuff stripped off and worked on making Pontiac the poor man's BMW. It hasn't been smooth going. Lutz earnestly compared the handling of some sporty front-drive Pontiacs with BMW's best. His first Pontiac-Holden hybrid was the quick but crude 2004 rear-drive GTO. And even now, the 2008 G6 GXP suffers some residual big-hair cheesiness. The front-drive G6's styling comes off as a bit common, Shipman thinks, so "we had to do something to maybe bring that out a little more. When you look at the G8 styling, the profile, the whole stance of the vehicle is unique. So we don't need to do the same thing to make this car stand out."
    Like Teddy Roosevelt, or the sublime M3, it walks softly and carries a big stick. Pontiac estimates the LS3 will scoot from standstill to 60 mph in 4.7 seconds, 0.6 second quicker than the G8 GT (which was 0.2 second quicker than the Dodge Charger R/T, as tested in our April issue). We have to bench-race the GXP for now. A 4.7-second 0-to-60-mph time would trump the Charger SRT8's 5.0 flat. Thanks to better handling and much better refinement, that 425-horsepower Charger won a two-car battle over the GTO in our December 2005 comparison, despite the LS2-powered Pontiac's quicker 0-to-60 sprint of-wait for it-4.7 seconds.
    How will Pontiac do it with a larger, heavier sedan? With precious little modification to the C6's 436-horsepower, 428-pound-foot LS3. There are a different water pump and exhaust manifold, and a slightly modified intake, mostly for packaging. "The Corvette is optimized for airflow," Shipman says. "This car isn't quite as optimized." As in the Corvette, the LS3 trumps the 6.0-liter LS2 with high-flow L92-style cylinder heads, unique camshaft and camshaft timing, a tweaked valvetrain with offset intake rocker arms, high-flow intake and fuel injectors. The extra 12 cubic inches is the result of a bigger bore, with larger-diameter cylinder heads and pistons for high-rpm performance.
    GXPs with the 6L80 six-speed Hydra-Matic automatic get a 3.27:1 final-drive ratio, and a Tremec TR6060 six-speed manual-this is the only G8 offered with a stick-comes with a 3.70:1 final drive. Pontiac rates both 402 horsepower at 6000 rpm. The automatic makes 402 pound-feet and the stick makes 400 at 4400 (all pending SAE certification). Shipman expects half of GXP buyers to choose the stick, which seems old-school-enthusiast optimistic to us. Hope he's right.
    How will the G8 GXP's handling compare with the Charger SRT8's? In our April story, Art St. Antoine found the G8 GT more nimble, with better handling than the Charger R/T's. And you can turn off the G8's StabiliTrak stability control, while the Charger's system refuses to give up completely.
    Predictably, the GXP's suspension will stiffens things up. It's race-ready with virtually no modifications, Shipman says. The MacPherson strut front and multilink coil-over rear carry forward with a direct-acting front anti-roll bar, decoupled rear stabilizer bar and lateral ball joints on the rear for more lateral stiffness. Caster, camber, and toe are adjustable in front, and camber and toe are adjustable in the rear. P245/40R19 summer tires are standard and limit the car's top speed to a near-autobahn-perfect 150 mph. All-season tires are among three options available on the GXP. The others are the transmission choice and a sunroof.
    Building a poor man's M5 is a tall order, though. BMW's ability to balance extreme handling prowess with a relatively supple ride is magic. "We don't want it to be too stiff, where it's bouncing you out of the car, but it's also got to have some performance," Shipman says. "So I think it's going to be a nice blend."
    We'll have to wait until we can get off the bench and test-drive the car before we find out whether Pontiac's formula works. GM, and particularly Pontiac, has a history of overstiffening and overtiring cars for high grip. Brembo is becoming the brake industry's answer to Bose car audio, and that's a good thing. The GXP upgrades to that brand with 14-inch, four-piston ventilated front rotors and 12.76-inch, single-piston ventilated rears. These should be good. The GT recorded a remarkably short 112-foot stop from 60 mph with 12.6-inch front/12.8-inch rear non-Brembo discs. GXP steering is unchanged from the standard G8, with the steering box located ahead of the front axle line for quicker and more direct feel.
    You'll control this from what's basically a fully loaded G8 interior, with the addition of new GXP logo-embroidered seatbacks, new display for battery voltage, oil temperature, and pressure out of the five-inch screen atop the center stack, GXP graphic on the gauge cluster, perforated leather-covered steering wheel and shift knob, and sport metallic pedals. Audio is a standard 230-watt Blaupunkt with XM radio.
    The only option beside the choice of automatic or manual and all-season or summer tires is a sunroof. Which leads to the question, how much? Pontiac isn't saying yet. The Charger SRT8's $39,218 base is a good starting point for an estimate. That includes a $2163 gas-guzzler tax for 13/18 mpg EPA numbers. Pontiac expects it'll have to fork over a gas-guzzler tax on the G8 GXP as well. If the G8 GT's $1435 base price advantage over the Charger R/T is any guide, this car could come in under $38 large, but don't count on it.
    The good news is that neither Pontiac nor Holden are production-constrained. So you and all your brothers and sisters can buy one and erase memories of the Widely Cladded Pontiacs once and for all.
    2009 PONTIAC G8 GXP
    BASE PRICE $38,000 (MT est)
    VEHICLE LAYOUT Front engine, RWD, 5-pass, 4-door sedan
    ENGINE 6.2L/402-hp/400-402-lb-ft OHV 16-valve V-8
    TRANSMISSIONS 6-speed manual; automatic
    CURB WEIGHT 4023-4050 lb (mfg)
    WHEELBASE 114.8 in.
    LENGTH x WIDTH x HEIGHT 196.1 x 74.8 x 57.7 in.
    0-60 MPH 4.7 sec (mfg)
    EPA CITY/HWY FUEL ECON Not yet tested
    CO2 EMISSIONS N/A
    ON SALE IN U.S. Late autumn 2008
    ALL CAPS JITB's Avatar
    I love g8's!
    agree!!!!!!
    Never go full retard
    Nashville
    Looks better than a Corvette...pfft. It's a cool car no doubt, but I mean, it's a pontiac.
    Pontiac is still a GM Duh
    Quote Originally Posted by Deke
    its actually a Holden commodore, which is a gm.. Saturn/pontiacs are now almost 100% euro opel/holden cars now..
    Nashville
    You win...you always do. I still think the Corvette looks better, but badass car no doubt.
    C.r.E.a.M MistaCee's Avatar
    Work
    I agree with thread title. That thing is nice.
    Nice Its GREAAAAAT
    C7 On_Her_Face's Avatar
    Duluth
    Fuck you, fuck the vette, fuck the gto, fuck the g8.
    /thread
    Duluth
    you just got that from the WL lol
    who'd thunk 2 years ago, there would be sooo many chevy/cadillac v8 lovers on IA... boy boy boy!
    Buslengths behind you
    CTS-V > XLR-V > Corvette > Camaro > G8 > GTO
    well you got one thing right on that list, GTO at the back. and i thought about adding all the caddilacs to the list but thought that would be too long of a title.
    Duluth
    i'm disappointed in you...
    cts or g8...i think i'd still get the g8 cuz insurance is still cheaper lol...and taxes..o yea...but that cts is uber hotness for really
    Daytona Beach
    noobs.
    Fuji made G.M.
    wth?
    Canton, GA
    woah i didnt know they came in a manual!!
    i would def rock one in black!!!
    Quote Originally Posted by Sport1.3
    only the gxp comes in manual. the reg g8 is an auto 6 speed
    gxp???
    Canton, GA
    awww...ok thats maybe why i was confused
    that is right i forgot there is a base model g8...but i saw a gxp w/ the LS engine in it w/ auto...(6speed) i believe
    Quote Originally Posted by PBS
    yea the base model has a ls2 i believe and the gxp has a ls3. the base has auto only while the gxp is available with both.
    ill post a pic
    Banned GirlieZ's Avatar
    boise
    the gto is a holden to: final assembly: holden, aust.
    but they new g8 gxp is sexy. collins needs to start his caddy job asap so i can get my discount on my grocery getter.
    as far as all pontiacs/saturns being eurp/holdens you have to look at it as being way cheaper for GM to just have one design and talior it to each market then go all out with different car types for each country. guess they are feeling the gas crunch too lol.
    guy was cool as the ocean breeze...talked to us for like 30-45minutes...he was an boxer
    here it tis:
    Dirk Diggler
    Columbus, GA
    The base V8 model is powered by the L76 engine. It's basically the same thing as an LS2, but the L76 uses Active Fuel Management and variable cam phasing.
    TJ
    For 2010:Stroker+Boost=:boobies:
    Quote Originally Posted by tj1986c
    TJ
    so you get decent gas mileage
    Quote Originally Posted by LS2_KID
    why?
    Duluth
    why?
    cause you are gay, sir.
    lol,i hate u
    jupiter
    my dad has an 08 G8 GT gun metal color....................wow that thing is sex. for 31,000 its a kick ass ride!!!!!!!!! pretty quick too....
    If I must have any "Moder American Muscle", it would be a Vauxhall Monaro VXR...
    Attached Thumbnails Attached Thumbnails -vauxhallmonarovxr2007-jpg
    Smyrna, GA
    better get one soon, rumor is that they are going to axe it like the GTO
