Results 1 to 15 of 15
Thread: rims,gauges,shift light,alarm
    lawrenceville
    Default rims,gauges,shift light,alarm
    1. Auto meter oil temperature phantom gauge- 40.00
    3.CRIME STOPPER CS2004WDC LOOKING FOR 40.00
    IT STILL WORKS FINE COMES WITH 2 REMOTES AND ALL WIRING MISSING ALARM HORN AND FLASHING LIGHT
    # SECURITY FEATURES: Includes Two 4 Button SecurGlow™ Transmitters
    # Dynamic Code Protection
    # On Board Starter Disable Relay with High Security Normally Open or Normally Closed Configuration
    # On Board Relays for Door Locks
    # On Board Relay for Flashing Parking Lights
    # Code Learning Receiver with Anti Scan Technology
    # Audible & Visual Arm / Disarm with Intrusion Alert
    # Dual Stage, Dual Adjustment Piezo Shock Sensor
    # Optional 2nd Sensor Port
    # Alarm Prewarning Signal
    # Sensor Bypass through Remote Control
    # Defective Zone Bypass with Warning Chirps
    # Remote Panic
    # Carjack Protection ( Passive or Active )
    # LED Status Indicator ( Plug in Design )
    # 6 Tone, 125 db Electronic Siren
    Passive or Active Arming mode ( Programmable ) Convenience and Value Added Features
    o Remote Keyless Entry with On Board Relays
    o Silent Arm/Disarm Through the Remote
    o Auto Lock / Unlock with Ignition ( Programmable )
    o Two Remote Auxiliary Outputs
    o Dome Light Illumination Output ( Requires Relay)
    o Parking Lights On with Disarm ( Programmable )
    o Passive Door Locks ( Programmable )
    o Double Unlock Pulse ( Programmable Feature for Factory Interface )
    o 1 or 3 Second Door Lock Pulse
    4. Group buy of pioneer 6x9 4 6x9's and 2 boxes ts-g970m 60.00 A powerful, 4-way 6 x 9 featuring 40 watts of power with a capacity for 240 watts of maximum power. Designed with an IMPP composite cone woofer, 2-5/8-inch film cone tweeter, 5/8-inch dome tweeter.
    5. Cerwin Vega ss-602 6.5 inches been sitting for a while still plays fine 30.00 Frequency respond: 90hz - 20Khz ± 3 dB
    Power handling: 50W RMS, 100W Max
    Nominal impedance: 4 ohm
    Sensitivy: 90 dB (1m/1W)
    6. 4 bII air pressure gauges runs up to 100 psi works fine 70.00 for all 4 or 25.00 each
    8. I have 2 racing hart cr for sale 17x7 inch 4 lug universal tires are no good have some scuffs but not real bad just need a good cleaning 100.00
    all items are also obo
    lawrenceville
    bump bump
    lawrenceville
    to the top
    lawrenceville
    lawrenceville
    bump bump bump
    Scottish Scotsman's Avatar
    on the road to recovery
    great seller , someone buy my boys shiit , its goin to a good cause (breast implants for his ole lady) lolz
    lawrenceville
    Quote Originally Posted by TheScotsman
    yes sir
    lawrenceville
    lawrenceville
    lawrenceville
    lawrenceville
    TTT
    -------DC4------- Azn-Boost's Avatar
    Oct 2003
    Lilburn
    check pm
    lawrenceville
    UP
    lawrenceville
    TTT
    lawrenceville
    ttt
