Thread: FS: 1988-1991 Civic/CRX SI Baer Big Brake kit
    1979 Civic Cvcc Saung's Avatar
    Tucker
    Default FS: 1988-1991 Civic/CRX SI Baer Big Brake kit
    The kit is like new, includes 13" rotors, like new pads, 2 piston calipers, brackets, little screws, joints. 400.00
    I'm in Tucker.
    Email:[email protected]
    home 678-395-7994 leave a meassage
    Flowery Branch
    trades?
    Tucker
    Sorry no trade. I'm moving so kinda doing a cleaning up sale so I don't have to pack, carry, load too much while I move....hehehe.
    I'm interested, what else would I need to full complete this swap on my Dx CRX? And this is for front ONLY I'm assuming.
    Tucker
    To be honest w/ you. I wouldn't know for sure if it will direct bolt on to your DX model. If your DX knuckles is the same as the SI model. This kit is a direct bolt on SI model which including my 1986 Civic SI model. I did tried it on my 86 SI and everything bolted onto the 86 Civic SI knuckles. Oh, the kit does comes w/ two rings to center the rotors and wheels. The only way to know for sure is if you take off your caliper than measure the two hole where the stock caliper bolt onto the knuckle. I hope I man any sense..
    Hey, nice mugen wheels. Are you selling them?
    Tucker
    The kit is mounted on my 1978 Civic CVCC in the pictures so I'm sure it will work on your DX or you might have to swap out your knuckles from DX to SI. I'm using a 1979 wagon knuckle there in the picture.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Just for your info, 88-91 Si and DX Knuckles are the same.
    I bet these huge brakes will throw me through the windshield
    So it will bolt-on to mine, but is this FRONT only?
    And since this use to be on your car then can you tell me exactly what I'd need to make this swap complete? (different/bigger brake booster and/or master cylinder, SS brake lines etc)
    Tucker
    Bigdare23, thanks for confirming the DX and SI knuckles are the same. Since your model is a DX you may consider upgrading your booster and master cylinder. I have a new Goodridge SS brake lines in the pack for a little extra. I have a 1996 GSR master cylinder you can have if you buy the kit. i hope this infos helps you out a little. Thanks.
