Thread: B16 flywheel
    Senior Member sakasaku's Avatar
    Marietta, GA
    Default B16 flywheel
    i am going to get my b16 flywheel resurfaced and how much should i have it lightend if at all it is going in a b18b ls all motor setup?
    thanx
    Lurking
    your moms house
    if i remember right the b16 flywheels weighs around 18lb's so if they can lighten it to around 12 it should be plenty
    had a stock flywheel lighten before..the lowest they went was 14 pound. That's just one place i went to.
    clayton county
    you shouldnt go past 13lbs, its already gonna loose alot of its structural mass and will run a high chance of exploding
    I give out reps....
    don't know about exploding, maybe cracking and breaking
    YEAH! bRiAnMcIvIcS's Avatar
    Just get an ITR Flywheel(15lbs).
    What is the cost of resurface+lighten compare to buying a new one? If it is not too much of a difference, I would get a new one to save the headache. Fidanza is good, and not that much. I have used them before, and no problem. But if you can spare more money, then it is better to get a 1 piece design flywheel like ACT Pro Lite or Street Lite. BTW, you won't feel any difference if you run ITR flywheel. It is not worth the money and time. I'm speaking from experience.
    Resident Isuzu Owner Lusos's Avatar
    Barnesville, Georgia
    I would just go with a Spec/Fidanza flywheel. the thought of the stock flywheel cracking or soming apart under high torque (about 3ft. lbs. for these cars, lol) really dosen't seem cool to me.
    "Silkie Johnson is nominated [Player Hater of the Year], for calling in a bomb threat... To the Special Olympics"
    Marietta, GA
    Quote Originally Posted by xbn83
    thuis was feee and it going to cost me 35 dollars to get it resurfaced
    Lurking
    I've heard the exedy flywheels(9.5lbs) are nice.
    rockem sohcem robot
    where do you get one lightened?
    Quote Originally Posted by masonhenson
    At a machine shop.
