Thread: HF crx to Z6 swap problems. Please help Really need this car running.
    Senior Member | IA Veteran Mad Mike's Avatar
    Gainesville
    Default HF crx to Z6 swap problems. Please help Really need this car running.
    On the distributer wires theres a yellow/green wire that is not matching up. I read on obd0 to obd1 distributer wire theres suppose to be a thick white and a thin white wire but on the stock HF engine harness the 2 white wires are the same size. Witch one do I connect the yellow/green to?
    Thanks
    Also yes I am going to soder and heat srink all connections.
    1.5T AnTi-PooN's Avatar
    L'villE
    mpfi?
    Gainesville
    no HF 1.5L (already has the MPFI) to Z6 swap. I bought a conversion harness for my dist. so I'm lost on this about the dang thick and thin white wires. There the same size on the HF engine harness.
    Gainesville
    bump for some badly needed help.
    I don't pull out... E=MC˛'s Avatar
    Where we like our sisters...
    i know this may be stupid but did you check a haynes manual?
    Gainesville
    The manuals don't cover engine swaps.
    I may have found the answer but its taken me over 4 hours of looking threw a bunch of web sites and reading threw 100s of post.
    if you peel the wire covers back further one if the wires is paired with another and is shielded, i believe its the thinner white wire. the thicker one is by itself and not shielded. and wtf are you doing, that things a mess
    Gainesville
    Thats the info I found a few min ago. Thanks for confirming it. My friends HF crx blew up coming up my road(big hill) so its been at my house for a few day. We found a Z6 with almost everything needed to swap it into his CRX for $500. Only problem is he cant afford a si transmission right now so we put the HF transmission on it until he can.
    Gainesville
    Thanks for the help the car is done and on the road and running good. Needs a new injector installed but other than that its good. Thanks
