Thread: overheating, sort of
    02 WRX patrick4588's Avatar
    warner robins
    Default overheating, sort of
    95 turbo gsr running a civic half size. its a single core, but its twice as thick as stock. anyway, when i was going to bleed the system the other day, i took the cap off; started the car and waited. the fan came on and all, but i never saw any coolant get sucked in or move. it just sat there. shouldnt i see the coolant moving? oh and the highest i let it get was half way and i turned the heat on and it dropped back to 1/4 of the way.
    GCO Member
    NRA Member
    warner robins
    it started getting hot on the way home tonight, so right when i got home, i popped the hood and went out to check it out. the radiator and radiator cap was not even hot!! it was luke warm at best, but the upper radiator hose had a ton of pressure on it. thermo failing in closed position?
    GCO Member
    NRA Member
    yeah that is usually caused by a bad thermostat, but anyways im a friend of chris with the boosted LS. he's racing this weekend you goin to run him
    warner robins
    ill run him from a roll tonight if he wants. anyway, back to the cooling problem. i swapped the thermostat today and tried to bleed the coolant system, but no coolant ever gets pulled through the radiator.
    GCO Member
    NRA Member
    Savannah
    did you try leaving the thermostat out? I went through three thremostats and they were all bad. Left the thermo out and problem solved.. til the fourth one comes in!
    warner robins
    i had no overheating today with the new thermo in
    GCO Member
    NRA Member
    Quote Originally Posted by Truegiant
    i always put mine in boiling water to make sure it works before installing it.
    warner robins
    ^^^good idea. ill remember that for next time
    GCO Member
    NRA Member
