Results 1 to 11 of 11
Thread: Headunit
    One Curve At A Time
    Default Headunit
    Isnt getting power, all fuses are good, and wires hooked up, but i touched the power wire and didnt get shocked. Any idea of where i should look?
    97 DX Civic w/ H22 FS
    freezrburn frostbyte's Avatar
    douglasville
    check for a fuse on rear of radio. if there is one and its good check all fuses again if all is good u prob fried the radio... sorry... also disconect the batt next time..
    U JUS GOT DROP KICKED IN THA FOREHEAD WITH A BROKEN CHEETOE!!! [SIGPIC]
    One Curve At A Time
    lol, yeahh, but now I know where the prob is, even if the radio is fried I should have gotten shocked, so the prob is a wire somewhere...I think
    no accord
    alpharetta
    put a meter on it, see if it is getting 12 volts, or use a test light
    RESIZE PIC PLEASE
    ______________
    It is 12 volts DC that wire should not shock you, so please do not use that to diagnose your problem either take it to a shop, or do like Sina said and use a meter
    wow this conversation really took place
    One Curve At A Time
    Well shouldnt it spark if the ground wire is put near it? it didnt spark, and I put a test light on it and it isnt getting power
    02 WRX patrick4588's Avatar
    warner robins
    then run new wires. your fuse box has empty spots for adding 12v constant and switched accessory
    GCO Member
    NRA Member
    Love da wifey Nex's Avatar
    it could be your backup fuse that is in your engine bay. If your clock seems dim then that should be it.
    One Curve At A Time
    Hmm, i'll check that tomorrow, we are going to rewire if we have to. Hopefully we'll get it working
    does your clock seem dim ?
