Results 1 to 2 of 2
Thread: Kenwood 9102D amp fs/ft
    Default Kenwood 9102D amp fs/ft
    I will post up actual pics of the amp when I get home tomorrow but it looks exactly like this one.
    Im looking to either sell it or possibly trade for car parts.
    price $400
    and it has only been used MAYBE for 2 weeks. I am also the only owner of this amp, it has not been whored around.
    Kenwood built the KAC-9102D amplifier from the ground up to power your subs with authority. Its rugged cast-aluminum chassis houses an efficient Class D mono power section that'll punch out up to 850 watts without putting a strain on your car's electrical system.
    A built-in low-pass filter adjusts amplifier output so you'll get the best sound possible from your subwoofer/box combo, while the subsonic filter eliminates inaudible, ultra-low bass that can hamper performance. Speaker- and preamp-level inputs, plus preamp outputs, provide flexibility in system design and hookup.
    The top-mounted controls allow you to tweak the sound easily, and convenient front-side connections make setup a snap.
    Details:
    * mono subwoofer amplifier
    * 500 watts RMS x 1 at 4 ohms (850 watts x 1 at 2 ohms)
    * variable low-pass filter (50-200 Hz at 24 dB per octave)
    * variable bass boost (0-18 dB at 40 Hz )
    * subsonic filter (15/25 Hz, 18 dB/octave )
    * top-mounted controls
    * Class D design
    * CEA-2006 compliant
    * speaker- and preamp-level inputs
    * preamp outputs
    * fuse rating: 30A x 2
    * 4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
    * 15"W x 2-7/16"H x 11-3/4"D
