Results 1 to 24 of 24
Thread: Honda, CEL code 13. Atmospheric Pressure?? *needs help!!*
    SwiperNoSwiping!!
    Exclamation Honda, CEL code 13. Atmospheric Pressure?? *needs help!!*
    My car just threw a code the other day on the ECU, code number 13. On G2IC, they say its the Atmospheric pressure, and its basically the barometric pressure sensor and what i was wondering, is if anyone could tell me where in the car this is located?? Because i talked to 2 Honda Specialists and both of them said its the 1st one they ever heard of going bad...So, im thinking it might not actually be bad, just the circuit or sensor could be loose.
    I have a 1990 Integra.
    R.I.P. LsVtec DB1....hello b20v EF...!
    u remind me of a wigger !
    freezrburn frostbyte's Avatar
    douglasville
    lol no mo honda can u bring me that motor?
    yes?
    ok ill leave the garage door open jus set it between he ole'accord and the 24o
    thanks see u soon...
    U JUS GOT DROP KICKED IN THA FOREHEAD WITH A BROKEN CHEETOE!!! [SIGPIC]
    lol i got that b!tch from GOOGLE lol
    ^^good job nomo
    douglasville
    welllllll tell mr.google i want one too...
    lol who names they kid google.. lol
    SwiperNoSwiping!!
    WOW, seriously?
    lol.....Shows how much I know...!
    turbos
    Quote Originally Posted by GM_TUNER
    barometric pressure sensor = IAT sensor :boobies:
    TOO BIG
    Quote Originally Posted by frostbyte
    done... he said he will lmk
    SwiperNoSwiping!!
    WTF, something else is wrong with my car. I dont know what in the world it is, but after making an attempt to remove the IAT, and failing, due to the screws on it being stripped (not by me), my car decides now that its Oxygen sensor is bad too! I know for a FACT that my oxygen sensor is not bad because its brand new.
    LoL also, i didnt even go anywhere NEAR the o2 sensor when i was taking things apart....
    Basically, its throwing code 1, and code 13.
    turbos
    check connections for both
    TOO BIG
    SwiperNoSwiping!!
    I tihnk my ECU has gone bad....
    Its throwing a cel code that doesnt even exist. Is there such thing as a code 4?
    Essentially, its throwing a code 4, a code 13, and a code 1.
    Augusta Ga
    lol your car cant make its mind up ... but yes change the ecu to a known good ecu and see if it helps .. if not . replace the sensors again ... and for the stripped screws ... may mr. dremel be your friend . cut a flathead groove on the screw and presto will come right out .
    93 sol Si
    95 sol S
    95 sol Si
    Quote Originally Posted by 1SOL2NV
    Augusta Ga
    wait till he tackles the tps sensor if he ever has to
    93 sol Si
    95 sol S
    95 sol Si
    SwiperNoSwiping!!
    But what is with the one code that supposedly doesnt even exist??
    code 4??
    Augusta Ga
    code 4??
    there is code 42 which is o2 heater malfunction ... 43 is fuel supply malfunction .... if its obd-1 ... since i dont know wut obd you are running i dunno o0o0o0 i jus read its a 90 teg ... i know **** about obd-0
    93 sol Si
    95 sol S
    95 sol Si
    SwiperNoSwiping!!
    obd0 is what im running, and according to the G2ic.com ecu code list, that one doesnt even exist at all.
    Augusta Ga
    ure probably missing a part of the "4" code ... its probably something like 42 ... check your CEl's again with a known good ecu man .
    93 sol Si
    95 sol S
    95 sol Si
    Augusta Ga
    hope this helps .... keep posted .
    93 sol Si
    95 sol S
    95 sol Si
    First and foremost:
    Please do not send me a PM asking, "I have #cel...how do I fix it?"
    I only list how to check the cel, I do not know how to fix every single issue that may pop up. A cel can come up for lots of reasons, so there is no one set answer for each of them.
    If you do get a cel, check the number here and then search for what other people have done...if you cant find an answer, make a new post about it.
    Again, do NOT send me a PM asking me to tell you how to fix it. The simple answer is that I cant...
    Do you have a CEL?
    Dont just reset the ecu by pulling the battery's neg. cable. Sure, that will reset the light, but youre not finding out whats wrong with your car! The light will always come back, until you fix it.
    This is how you check your own cel (Check Engine Light), at home, without driving to a mechanic, auto store, dealer. Numbers for the light are listed farther below.
    5 Easy to Follow Steps:
    1) Get a CEL
    2) On the passener side, remove the kick panel at the floor.
    Behind it, is your ecu and a jumper plug.
    3) Locate the jumper plug (Civic 92-95 is grey, 96-00 its blue). Its a 2 pin plug.
    (I am not sure if the connector is in the same location for all hondas..I assume so - I dont know all the connector colors...)
    For EK, there is 1 brown wire and 1 black wire
    For EG, there is 1 tan wire and 1 green
    4) WITH THE CAR OFF, insert either a 2pin connector clip, or loop a thin enough piece of wire into both holes on the connector.
    5) Back in the driver's seat, turn the key to the 'ON' position. The CEL light will come on at startup, like normal, but it will then begin to flash.
    **By counting the number of flashes, you can decipher the CEL #.
    SHORT flashes are single digits (1/2 second)
    LONG flashes are 10's (1 second)
    -----CEL # List-----
    1 O2A - Oxygen sensor #1
    2 O2B - Oxygen sensor #2
    3 MAP - manifold absolute pressure sensor
    4 CKP - crank position sensor
    5 MAP - manifold absolute pressure sensor
    6 ECT - water temperature sensor
    7 TPS - throttle position sensor
    8 TDC - top dead centre sensor
    9 CYP - cylinder sensor
    10 IAT - intake air temperature sensor
    12 EGR - exhaust gas recirculation lift valve
    13 BARO - atmospheric pressure sensor
    14 IAC (EACV) - idle air control valve
    15 Ignition output signal
    16 Fuel injectors
    17 VSS - speed sensor
    19 Automatic transmission lockup control valve
    20 Electrical load detector
    21 VTEC spool solenoid valve
    22 VTEC pressure valve
    23 Knock sensor
    30 Automatic transmission A signal
    31 Automatic transmission B signal
    36 traction control found on JDM ecu's
    41 Primary oxygen sensor heater
    43 Fuel supply system
    45 Fuel system too rich or lean
    48 LAF - lean air fuel sensor
    54 CKF - crank fluctuation sensor
    58 TDC sensor #2
    61 Primary oxygen sensor
    63 Secondary oxygen sensor circuit
    65 Secondary oxygen sensor heater wire (black wires)
    67 Cat Converter
    71 random misfire cylinder 1
    72 random misfire cylinder 2
    73 random misfire cylinder 3
    74 random misfire cylinder 4
    80 EGR Valve/Line
    86 ECT sensor - Cooling System
    91 Fuel Tank pressure sensor
    92 EVAP Solenoid/Valve/Vacuum Lines
    Augusta Ga
    for future reference if you get these 4 codes all at once .... its honda's way of telling you go BUY SOME GAS for the car bcuz its empty ... lmao !! had 2 cars that wouldnt start and had aftermarket fuel pumps with these codes in it and the tank was registering 1/4 and the car wouldnt crank .... put 3 gallons in and it ran like a champ after sitting for 4 years ( 97 del sol si ) am not metioning any names but i thought i would share this useless info lmao
    93 sol Si
    95 sol S
    95 sol Si
    SwiperNoSwiping!!
    its all good you guys, i picked up a spare ecu from one of my friends the other night, but since ill be out of town for the next few days, i wont be getting a chance to test it out until next week. ill keep you all posted as to how it goes. the ecu he gave me also has less sensors in it according to him, so ill still have to pick up another nother stock ls ecu some time before i have to get my emissions done......
