Results 1 to 23 of 23
Thread: A/C guru's need help
    Scottish Scotsman's Avatar
    on the road to recovery
    Default A/C guru's need help
    i have a 94' civic sedan , my A/C is at 45 psi , and it is not blowin cold air , my fan runs , but mildly cold air , any advice on what i should try to replace or fix will be greatly appreciated , i have my two yr old son for most of this summer it is gettin too hot for my lil man
    got air? Bud's Avatar
    northside
    compressor locked?
    im not an a/c guru but do u got any water coming out of the vents
    nope , just very mildly cold air , it might only have been cold to me cuz i was sweatin my ballz off , when i push the A/C button , my rpm's do jump up a lil , if that helps at all
    IA Member jtaylor48's Avatar
    It might just need to be recharged. If you don't use your a/c for a while the freon (sp.) can go bad so I've heard. Try to just recharge or run up to a jiffy lube and they do it for cheap.
    it is fully charged hence the 45psi
    turbos
    Do any of ur vents feel like they are blowing colder than others if so
    u need to replace the expansion valve under the dashboard
    part # from honda is 533221
    TOO BIG
    Senior Member mccoy1178's Avatar
    try to get it vacuumed and recharged. i put my freon in too and my car is not that hot. it might have air in the lines. hope it works
    45psi on the low side,(which is a tad high) but what does the high side read?
    .:L0N3LY_B0Y:. 1MP0RTL0V3R's Avatar
    maybe the air contol is messed up i dnt remember what its called but if it only blows it when its on high it could be the i think its called speed regulator or something like that ive heard my uncle say it once but that was about it.
    JDM TYTE AnthonyF's Avatar
    A/C systems work like this....if you want to fix the problem u must replace nearly everything. Replace ur dryer, comperssor, condensor and the little block...forgot the name and I always forget. lol. Make sure u pour rubbing alcohol in the lines and use high pressure air to force it though to clean the lines out of old "junk".
    -Ant.
    The Carbon Fibered R6
    45psi is too high. That may be one of your problems. And like someone else asked, whats the high side reading?
    -Ant.
    That couldn't be further from the truth.
    turbos
    try the expansion valve first on the parts to replace, it usually gets clogged after tthe system has not been used for a while, it is also probubly the cheapest part of the A/C system
    TOO BIG
    Quote Originally Posted by Init2winit
    what?
    -Ant.
    He meens that if you dont know how to diagnose things, then you usually replace all the parts.
    I am not going to diagnose a mystery problem over the intranet. Know how impossible that is? lol. I mean, if he brought it to my shop I could figure it out, but since most parts for a honda is like going to McD's dollar menu then I would just get one of everything.
    -Ant.
    turbos
    -Ant.
    I wish this was true
    TOO BIG
    ^it is for me and people who work at shops. hehe.
    -Ant.
    turbos
    -Ant.
    damn u and ur good prices, i am forced to buy second hand stuff cuz im a cheap ass
    TOO BIG
    -Ant.
    oooo yah
    Quote Originally Posted by seanrg1116
    gotta do whatcha gotta do. We all have done it before.
    -Ant.
    clayton county
    my old compressor stoppped my ac from working. The "clutch" or whatever had went out. I.E. when you turn aC on, you'll hear a click. that means your compressor had started. well based on what i went thru, that was the case.
    I give out reps....
