Thread: ls throttle body on a gsr
    Default ls throttle body on a gsr
    ok i need help on swapin an ls throttle body on an 2000 gsr its in a 92 da an the throttle cable seems like it needs to be bolted diff any help on what i should do
    turbos
    why the change just keep the GSR one on there
    TOO BIG
    Hwy 315
    the throttle cable brackets are different.
    If you're using the stock GSR manifold, you'll have to find a way to brace the throttle cable.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    clayton county
    why use a LS throttle body on a GSR?
    I give out reps....
    SOUTHSIDE
    get a gsr throttle cable
    Marietta, GA
    I don't get it, why change throttle bodies? is the cable position different on a da or something?I know you won't get any more power out of just swapping stock throttle bodies.
