Thread: Chain Lube
    Monroe, Ga
    Default Chain Lube
    How in the hell do you get this **** off of everything, i went and got new tires and the lubed my chain and this **** is all over my rim and when i try to clean it all it does is smear worse, what the hell
    Jamaican
    U use wd 40. It will cut the grease
    Jaszen
    correct...once you clean it very well, so that it shines like the sun lol....go around the block for about 10mins to get the chain warm then I use chain wax an lightly spray it an allow 15mins to dry then your good to go...
    Quote Originally Posted by Jaszen1
    Monroe, Ga
    thanks guys ill try it
    yea I used chain wax too, works good
    Toyota Tech
    Dec 2003
    Claxton, GA
    i use kerosene to clean chain and all around the sprockets where its slung at, drive it around block get chain dry and warm, then chain wax, then let sit overnight so it will tacky up and not sling everywhere lol. Kerosene and a grunge brush cleans it up real good
    2010 Scion xB
    Chain wax only needs 10-15mins drying time
    blank
    nowhere
    honda cleaner works well also
