in 4-2-1 header do you have to use a gasket between when the pipe goes from four into two? or can you just bolt it up?
Anywhere there is a connection, there is a gasket.
And by the way, you only have a header. Just one. Unless you have a v8 or v6 swap... or even a v4 swap... but yeah... just one header.
I know but can it run properly without a gasket?
lol buy the gasket
U JUS GOT DROP KICKED IN THA FOREHEAD WITH A BROKEN CHEETOE!!!
[SIGPIC]
yeah dude dont run without the gasket. your gonna **** up your motor
1993 Honda Civic EX
1993 Acura Integra
1998 DB7 Integra
1989 Toyota Supra
1993 Toyota Supra
if its a two piece header i thought it came with those two donut rings for inbetween... thats how mine is on my b-series no gasket
AKA YAKUZA
MAINSTREAM PERFORMANCE 678-567-9384
it came with a gasket and it cracked.. but my friend has DC header and it didn't have a gasket and it ran fine..
has those 2 donut rings right?
AKA YAKUZA
i didnt see any donut rings..
I have the same problem. Did a H22 swap on a 93 Accord and the guy I bought the header from did not have the gasket between the header and downpipe. No gasket for me means a huge exhaust leak, and it sounds like POOH! What if you cannot get the gasket? Is it possible to get one made or
DIY one?
Does yours look like this?
http://store.summitracing.com/partde...5&autoview=sku
Going down to Summit tomorrow, woohoo.
If you can't find a gasket that works in some way, shape, or form on your car, you're just wee-todd-did
yea it looked like that
aftermarket header require "4 into 2" gasket? my ls header doesnt have gasket in between header and downpipe and it didnt have exhaust leak.
Whatever you do, don't make a gasket out of gasket paper..... Does not last that long!
"Damn, Its Tyler"RaceReadyDevelopments
x2
Picked up the gasket $10.49 with tax and car is quiet as OE. Nice. Summit had the gasket in stock too. BTW, I tried that gasket paper also and when I took the header and downpipe off the paper $10 gasket from Summit.![]()
You can't run w/o a gasket because you WILL have an exhaust leak which reduces back pressure and loss of power, it can also cause engine damage along with a horrible gaseous smell (from the leak) and horrible gas mileage. I purchased BBK headers for my old car (02' Mustang GT) and installed the gaskets that came w/ the kit....they were s**t... pretty much like tin foil, so after a week they leaked so it's no surprise you had crappy gaskets come w/ ur header. I'd recommend what I had to do, buy high quality gaskets (I bought copper one's from Summit) and red RTV the bad boys on!
1989 240sx Coupe LS1
2005 Srt-4
