Results 1 to 24 of 24
Thread: Eff'ed up transmission
    Unhappy Third to first at 3000 rpm
    95 Golf III automatic. Went from drive to first at around.. 35 mph? 3000 rpm.
    First just revs and sounds like it's going to stall.
    Everything sounds almost normal in third. but revs too fast and there's a sort of grinding?
    And in drive after 40 mph it's slow going. takes a while to get to 60.
    Doesn't seem like a problem that will fix itself so.. anyone know of a good VW place? Or know someone that knows volkswagen transmission well?
    Any help at all would be greeeat!
    Oh and my speedometer goes all wacky sometimes now.
    I have no idea wtf you are saying.
    I'm saying that as i was driving - thru a neighborhood - i ended up shifting from D to 1. I shifted from third to drive to third but my shifter jumped to first. and now my transmission is about to die. does that help clarify
    the start of 285
    is it an auto? were u gate shifting?
    Sounds like you're and idiot. Not sure though.
    Quote Originally Posted by 81911SC
    that would be correct
    Quote Originally Posted by EcKoBoi770
    Yes it's automatic.
    I was trying out a fuel saving technique.
    You get up your rpms - shut off the engine and coast pretty much.
    I took it up to 3000 rpm in third. then shut off the engine as i start up this little hill.
    I was in drive for some reason so i go to shift back into third but my shifter slips into first. my car is old and shoddy - but yeah - it wasn't s'pposed to be in first.
    So now my transmission is wrecked - yes i know i'm an idiot. i just wanna get it fixed.
    A push in the right direction is all i need.
    ok whats it doing now
    I'm not sure but when you started to go up the hill that moved your blocking rings into your dumbass. You have a broken dumbass.
    lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololololololo lololololololololololololololololololololol
    Kinda noisy in all the gears. Drive is fine up 'til 40 mph then it seems like everyone is passing me.
    First is gone. Just revs and i might roll forward a bit.
    When i press on the gas at highway speed there's a high pitched revving/squealing but goes away when i let off.
    Is it fixable? Or should i replace it?
    replace no bs
    Why thank you.
    Why thank you.
    what can i say i thought it was funny as hell as u can see
    Repped back brother.
    the start of 285
    hmm.. i don't know what to tell you man. when my tranny was screwed i wasnt able to get into 2nd at all.... it just redlined and **** wouldnt engaged.
    if anything check back in this thread, i'm sure more knowledgeable ppl will pop in..
    i hope
    replace no bs
    must be talkin to myself again.
    Senior Member G.C's Avatar
    Forgot
    i dont know what your talking bout but automatic is not stick shift. you dont move them around.
    :idb:
    Quote Originally Posted by Genji
    Yes it's automatic.
    Never under any circumstances should you put an automatic transmission in neutral, or shut off the engine while driving. You just found out first hand what can happen.
    FLOSSIN' MR.EM1's Avatar
    laughed hard not gonna lie
    FL
    ATL's Slow3st DSM!!! Ronsam2006's Avatar
    Man it sounds like your transmission is shot. Best bet is to call some transmission places up. Just go to google and type in your city along with the word "transmission". Some of these places are really nice and will point you in the right direction.
    Honestly, your cheapest route would be getting a used one. You'll probably spend more re-building the trans propperly than the car is worth.
    Quote Originally Posted by Init2winit
    x2 sometimes lessons have to learned the hard way, just cause you can do that in a manual trans car doesnt mean you can do it in an auto
