Results 1 to 18 of 18
Thread: h22 help...neep professional help
    SOUTHSIDE
    Default h22 help...neep professional help
    okay this the deal i got a 99 prelude came with a h22 but it blew up now i drop in a jdm h22 but the jdm h22 doesnt have the ckp sensor...but it has it in the jdm dizzy now i have the jdm dizzy but its obd1 the plugs dont line up and you need to run the sensors...also the prelude has an external coil and the jdm dizzy has an internal...i need someone to wire this up for me so it can crank up...i need this done asap....
    use your obd2 dizzy and if you have the jdm ecu run it with that u should be good
    victory is mine .::UNKNOWN::.'s Avatar
    jonesboro, ga
    use your dizzy off the old motor and i am not sure about the ckp sensor tho i am an obd1 guy..... the jdm ecu has a speed limiter of 181kph which comes out at 118.28129849023490823 mph so if you are cool with the speed limiter use the jdm ecu but your ecu will do just fine
    NO NWS
    you have to change the oil pump to be able to use the CRK sensor...! an yes use your factory dizzy ...
    BTW pm me I will buy your blown H22
    SOUTHSIDE
    i'm using the stock ecu since its a h22 ecu and it has the immoblieizer but i already drop the swap in and i really dont want to put it back out to change the oil pump out since the timing on a h22 is hard its not like a b series timing...
    Southside of The Jungle
    So what do you want done and where are you located in clayco.
    Quote Originally Posted by wrekonize
    ive done plenty inside the car it aint all that hard.
    clayton county
    he wants dizzy swap wiring done... he stays very close to both of us.. i think its jr.s brother lol
    I give out reps....
    you could bypass the cfk sensor...!
    SOUTHSIDE
    yeah thats what i need
    Quote Originally Posted by Uptown401
    i looked at the ecu pinout when he first posted and didnt see a way.
    New York Affiliate TRUTH's Avatar
    Near Kennesaw
    WE CAN DO IT AT MAINSTREAM PERFORMANCE!!!!!! 6785679384
    AKA YAKUZA
    MAINSTREAM PERFORMANCE 678-567-9384
    yeah But he will never pass emissions
    1.5T AnTi-PooN's Avatar
    L'villE
    ^^^^^^its over rated
    you can bypass the CFK really easily an you will pass emissions.
    Follow this guide
    http://technet.ff-squad.com/ckftrick.htm
    SOUTHSIDE
    thanks every one.... i just gave up on bypassing or wiring...so i changes out the jdm oil pump with the usdm one and used the usdm ckp sensors and stayed with the external coil dizzy..its running perfectly....
    Follow this guide
    sry the guide doesnt work for h22 harness or if it does they arent labeled the same.
