Results 1 to 14 of 14
Thread: rsx k24
    Enterprise AL,
    Default rsx k24
    ok i have a 2002 rsx k24 swap my a/c stopd workin the other day compresr and a/c fan will not kick in fuse is ok lmk what u think
    what
    Riversider
    what
    Southside of The Jungle
    what
    B5 S4=problems Reaper's Avatar
    Crossfit
    what
    your moms house
    the system is low on freon it keeps the compressor and fan from kicking in to keep from causing damage to the compressor when it's low on freon
    wat
    Enterprise AL,
    what about the heater i cant get nothing out of the a/c heat or cold
    your moms house
    couldn't answer that
    Vuong's Garage lxpaulxl's Avatar
    Quote Originally Posted by rsxdc52002
    As for your heater, bleed your coolant.
    double check on the ac compressor harness on engine bay....and for the heat look under dash to find the fan unit if everythings good, ur heater and ac relay is burnt.
    Enterprise AL,
    where could i look to find this relay?
    KiLLa K
    acworth
    is your blower working????
    Enterprise AL,
    well the a/c started workin a week ago and has been ever since??????? it does this all the time when it stops normally the hole thing stops no fan no cold air no heat nothin
