Results 1 to 5 of 5
Thread: fuel problem/running problem
    Default fuel problem/running problem
    im havin an hard time to get my car to start it will start if i spray gas in it but after i stop sprayin gas it cuts right off i didnt know if it could be the fuel pressure regulator someone said its not gettin enough gas when it does this.
    Crash
    Snellville, GA
    your car isnt getting enough fuel running through it. check all your fuel related parts, best place to start
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    Default hey
    Quote Originally Posted by suprapower
    thanks for the info other had said the same but not what to check for i got an new relay fuel pump works just dont know what else it could be
    SwiperNoSwiping!!
    goodness man!
    whatever happened with the injectors?? Also, did you check your fuel filter?
    Also, since ur BOOSTED dont mess with stuff that doesnt really need to be messed with, you may complicate things... lik, dont change the psi on the FPR if its not neccessary, things like that.
    u remind me of a wigger !
    do you hear the pump running? thats where i would start, then id open up the fuel line and get some one to switch the key over and look at the gas as its coming out(make sure to catch in a jug), if its coming out fine id move further up in the system, and either way i went id change the fuel filter
