Thread: 94 civic injector problem
    Need Parts!
    Canton
    Default 94 civic injector problem
    i have a 94 civic and i just did a motor swap, but the number 1 and 3 injectors get fuel when key is just turned on. then 3 and 4 get nothing. when you try to start the same thing. any ideas?
    sounds like a electrical problem to me
    Augusta Ga
    buy some injectors .. there is a ****load in junkyards .... or check ecu and wire harness .... the clips wire might be bad .....
    93 sol Si
    95 sol S
    95 sol Si
    thats what it sounds like to me. when in the electrical im not sure but something isnt right.
    you dont need to know
    buy a noid light to see if it is the injectors, and go from there they may be cloged.
    f*ck off
    center field
    ^^^^ like he said u can get them at auto zone, that let u know if it is the injectors
    Need Parts!
    Canton
    ok ill try that
    sounds like the clips arent making contact.
    Get a noid light.
    Did you do any distributor wiring?
