Results 1 to 16 of 16
Thread: What 1/4 mile should I expect
    Default What 1/4 mile should I expect
    What should I expect to run with my '90 GSX?
    Stock 14b turbo, fmic, clutch, 3" TBE, 2g MAS, spec stg3 clutch, running 13ish PSI, and a couple other things.
    Slow
    Marietta, GA
    Probably 15s if you really rip it.
    knowing what all you told me, and granny shifting maybe mid 15 if you get a good launch
    has web street grind cams, lobes pretty hard.
    very true heard it sounds like a beast
    Buslengths behind you
    id say high 14 low 15
    Warner robins ,Ga
    10 sec! haha jk 14.5
    cack suckers.
    ATL's Slow3st DSM!!! Ronsam2006's Avatar
    14.5. IF you get a 14 flat...you are a good driver. Not saying its impossible.
    Certified Gearhead koi's Avatar
    Covington
    With a 2g on a 14b and stock boost with stock exhaust I hit a 15.4. But I'm also heavier then most DSM's by about 200-300 pounds. Not sure if that helps any. But you should be around that time if not lower.
    Koi
    Proud former owner and future owner of a 1996 Mitshibishi Eclipse Spyder GSX(AWD). Ready to sell it back to me yet, Vonrok?
    tawksick. toxxxic's Avatar
    Roswell
    20 minutes. =)
    Newnan
    wow, I thought the gsx's were quicker than that
    Ft Myers, FL
    I had no problem beating one with my 03 Tib a few years ago...they slow...
    Newnan
    im sure you can turn up boost and tune maybe some injectors and hit 13's at least right?
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    I wouldn't boost too much more, thats motors prolly not in the best condition after 18 years of boost unless its been rebuilt/replaced/built.....i'd say low 14's with a great 60' and a good driver. Just rip everything out before you hit the track, interior wise at least.
    Unknown
    Honolulu, HI
    Quote Originally Posted by IndianStig
    Very bad advise! This isn't a high compression motor or weak. To the OP just sell the car before you **** it up. If you have to ask on a site like this your only asking for trouble.
