Thread: A/C Problems with Civic, need help
    Certified Gearhead ATLem1's Avatar
    west
    Default A/C Problems with Civic, need help
    okay.. heres the deal... its an 00 civic. the car didnt have all the a/c parts under the hood like the condensor, the small harness right around there and a compressor, so i pieced it together. i've try'd chargin it with the self charge kits.. and the pressure gauge on the hose goes up and up but the compressor never kicks on.. i've try'd jumpin the pressure switch to force the compressor on and that didnt work either.. i've checked any a/c related fuses, the relay in the fuse box under the hood and i've about given up...if some one can offer some advice or recommend a reasonable a/c person on the westside of ATL, pm me..
    ****please be aware of the rules under the "solicitation of labor" thread above. i dont want anyone to get banned.
    thanks
    Cobb County
    Civics comes with A/C????? WTF!
    Lol.
    west
    up ^^^
    west
    up
    Augusta Ga
    when you pieced together this a/c .. had the guy you bought the compressor from tell you that both lines for the compressor been sealed ? .. sounds to me like a bad compressor and for one that has sat in someones garage for a while unprotected will not work .
    93 sol Si
    95 sol S
    95 sol Si
    Crash
    Snellville, GA
    i say get a new compressor. that one is probably****ed up
    1993 Honda Civic EX
    1993 Acura Integra
    1998 DB7 Integra
    1989 Toyota Supra
    1993 Toyota Supra
    west
    thanks but this is my second compressor... it was pulled from a car that had a charged system... its doin the same thing that the first one did.............. nothing. so im guessin its something other than the compressor.
    west
    up
    Middle, Ga
    I say remove the A/C and roll down your windows....lol
    "Damn, Its Tyler"
    RaceReadyDevelopments
    newly tuning '94 EJ
    Alpharetta
    You did vacuum the system first right? You can't charge a system without vacuuming it first. Also you could have water in your system.
    west
    Quote Originally Posted by highlytuned
    honestly i didnt ... ithaught maybe i could get away without it.. but i'll give it a try. i'll have to give it out to get done then. thanks all.
    Southside
    if you didn't vacuum the system before rechargin then I'm afraid your compressor may have burned up..check that out as well.
