Results 1 to 30 of 30
Thread: Canon EOS Rebel K2 35mm SLR
    Default Canon EOS Rebel K2 35mm SLR
    I have a Canon Rebel K2. I bought it in January of 2007 for a photography class. Used one roll of film and then droped the class. The camera is in perfect condition. It looks brand new and functions brand new. Its been sitting in the box in my room ever since. Comes with everything that came in the box. Asking $150 obo.
    -EOS Rebel K2 body
    -EF28-90mm f/4-5.6 lens
    -Canon wide neck strap
    -owner's manual
    Here is some pictures of it and extra information.
    Product Features
    • 35-zone metering system linked to 7-point high speed autofocus system
    • 12 shooting modes including 7 programmed image control modes
    • Advanced E-TTL flash metering system
    • Futuristic styling, innovative control layout and large LCD panel
    • Standard 28 to 90 mm (3.2x) zoom lens with quiet ultrasonic motor
    Technical Details
    • Camera type: 35mm focal plane shutter SLR (single-lens reflex) autofocus/autoexposure camera with built-in motor drive and retractable flash
    • Lens mount: Canon EF mount (electronic signal transfer system)
    • Usable lenses: Canon EF lenses (except EF-S)
    • Lens focal length: 28 to 90 millimeters
    • Maximum aperture: f4 to f5.6
    • Lens construction: 10 elements in 8 groups
    • Diagonal angle of view: 75 to 27 degrees
    • Focus adjustment: Front-focusing method with USM
    • Closest focusing distance: 1.25 feet
    • Zoom system: Rotating type
    • Filter size: 58 millimeters
    • Viewfinder: SLR-type, eye-level roof prism mirror gives 90 percent vertical and horizontal coverage of actual picture area and 0.70x magnification with 50mm lens at infinity
    • Mirror: Quick-return half mirror
    • Standard diopter: Adjusted to -1. (18.5 mm eye relief)
    • Focusing screen: Fixed, full-surface new laser-matte screen marked with focusing points
    • Viewfinder information: Numbers and symbols displayed by LCD at bottom of viewing area. (Yellow-Green)
    • Viewfinder display: 1. Shutter speed (If unsuitable blinks at 2 Hz as a warning.) 2. Aperture (If unsuitable blinks at 2 Hz as a warning.), 3. Indicates AE lock or FE lock (partial metering at center.), 4. Exposure level scale with dot indicators in 1/2-stop increments. (plus or minus 2 stops), 5. Lights when flash is ready; blinks at 2 Hz if flash range is ineffective during FE lock, 6. Lights during high-speed sync. (FP flash) 7. In-focus indicator. (blinks at 2 Hz if focus cannot be achieved.) 8. AF point selection and active AF point are indicated.
    • Shutter: Vertical-travel, focal plane shutter with all speeds electronically controlled. Front and rear shutter curtains both have dedicated electromagnetic release control (curtain speed: 6.3ms / 24mm)
    • Shutter speeds: 30 to 1/2000 seconds, bulb; X-sync at 1/90 seconds. Can be set in 1/2-stop increments
    • AF control system: TTL-SIR (secondary image registration) CMOS sensor
    • Focusing point selection: The focusing point can be selected by camera (automatic) or by user (manual)
    • Focus modes: 1. Autofocus (One of the following three AF modes is set automatically depending on the picture-taking mode. The shutter does not release until focus is achieved): a. One-shot AF: autofocus locks when focusing is achieved, b. predictive AI servo AF: continuously tracks subject movement and achieves focus before the exposure starts, c. AI focus AF for automatic switching between one-shot AF and predictive AF for moving subjects. 2. Manual focus setting the lens' focus mode switch to MF enables manual focusing with the focusing ring.
    • Focus operation: Autofocus is activated by pressing the shutter button halfway
    • AF working range: EV1-18 (at ISO100)
    • AF-assist beam: Automatically emitted when necessary and aimed at the area covered by the active focus point.
    • Light metering: 1. TTL full-aperture metering using 35-zone SPC (silicon photocell). Three metering patterns available: a. 35-zone evaluative metering, b. Central partial metering which covers approximately 9.5 percent of finder area, c. Center weighted average metering (set automatically in M mode.). 2. E-TTL: 7-point, 35-zone pre-flash metering using Speedlite 550EX, 420EX, or 220EX. 3. A-TTL, TTL flash metering: off-the-film, 3-zone A-TTL autoflash linked to focusing points, 3-zone TTL autoflash metering.
    • Metering range: EV 1 to 20 (with 50 mm f1.4 lens at ISO 100)
    • Exposure modes: 1. Intelligent program AE with variable shift, 2. Shutter speed-priority AE, 3. Aperture-priority AE, 4. Auto DEP, 5. Full auto (intelligent program AE, unshiftable), 6. Programmed image control modes: portrait, landscape, close-up, sports, night portrait and flash off, 7. E-TTL program flash AE, 8. A-TTL program flash AE, 9. TTL program flash AE, 10. Metered manual
    • Exposure compensation: 1. Auto exposure bracketing (AEB) up to plus or minus 2EV in 1/2 steps. 2. Manual exposure compensation up to plus or minus 2 EV in 1/2 steps. 3. Unavailable in the full auto and programmed modes.
    • Multiple exposure: Up to 9 exposures can be preset. Automatically clears upon completion. Cancelable midway.
    • Film speed setting: ISO 25-5000 automatically set in 1/3 step increments according to DX code. Can also be set manually from ISO 6-6400 in 1/3 step increments.
    • Film loading: Automatic prewind system. After film positioning and back cover closure, the film automatically winds to the 1st frame.
    • Film transport: Single-frame advance or continuous advance set automatically according to the picture-taking mode.
    • Film wind: One of two modes can be set: single frame and continuous. (In continuous mode, with AF locked, approximately 1.5 fps.)
    • Film rewind: Automatically rewinds at the end of roll. Midroll rewinding possible.
    • Quiet film transport: Film winding sound level: approximately 60dB
    • Film transport confirmation: By up/down counting of frame counter in LCD panel.
    • Flash type: Built-in, retractable TTL autoflash head in the pentaprism. Auto pop-up and serial-controlled.
    • Guide number: 39 feet (ISO 100)
    • Flash coverage angle: Covers the angle of view of 28 mm lens.
    • Recycling time: Approximately 2 seconds. The icon lights in viewfinder when ready
    • Flash duration / color: 1ms or less/equivalent to daylight
    • Shooting distance range(ISO : wide: 28 mm negative film, wide: 28 mm reversal film, tele: 80 mm negative film, tele: 80 mm reversal film): 100 : 3.0 feet to 4.6 feet, 3.0 feet to 9.8 feet, 3.0 feet to 9.8 feet, 3.0 feet to 6.9 feet; 200 : 3.0 feet to 19.7 feet, 3.0 feet to 13.8 feet, 3.0 feet to 14.1 feet, 3.0 feet to 9.8 feet; 400 : 3.0 feet to 27.9 feet, 3.9 feet to 19.7 feet, 3.0 feet to 19.7 feet, 3.0 feet to 14.1 feet
    • Red-eye reduction: Red-eye reduction lamp lights while the shutter button is pressed halfway and focusing and metering are achieved.
    • Battery: Two CR2 lithium batteries housed inside the camera grip
    • Battery check: Battery level is displayed by the battery level indicator on the LCD panel. Battery level is indicated in one of four levels.
    • Shooting capacity (ambient temperature: flash not used, 50 percent with flash, 100 percent flash use): Normal temperature (68 degrees F / 20 degrees C): 67, 30, 22; low temperature(4 degrees F / -20 degrees C): 44, 20, 15
    • Shooting modes: Full auto, portrait, landscape, close-up, sports, night scene, flash off, intelligent program AE, shutter speed-priority AE, aperture-priority AE, manual exposure, automatic depth-of-field AE
    • Continuous shooting: Approximately 1.5 images/second
    • Lens diameter: 2.6 inches
    • Lens length: 2.8 inches
    • Lens weight: 6.7 ounces
    • Width: 5.1 inches
    • Height: 3.5 inches
    • Depth: 2.5 inches
    • Weight: 12.9 ounces (without batteries)
    sorry, just trying to get it sold.
    bumppp
    Oh U KnoW meH
    biloxi,ms
    put some pics up that you took with it. will help the sale
    dteng Homer Simpson's Avatar
    Evergreen Terrace
    bump for tommy.
    can vouch for the camera, takes awesome pictures!
    scroll down for examples
    dteng's pics from the v-meet
    thanks david.
    bumppp;
    97 Accord
    Gainesville
    Too bad it wasn't digital I would have bought it. But bump for a great camera
    IA's Instigator
    Statesboro
    my offer is still up for you
    Quote Originally Posted by yogi08
    haha i about forgot about it. i know if i keep it, ill just cause some trouble, so if i find someone that wants to buy that, then i will trade you.
    IA's Instigator
    Statesboro
    nice nice. well, ill promise you you wont get in much trouble with it. as long as you dont ever point it at anybody anyways.
    BUMP
    again..
    bumpppppp
    again
    Middle, Ga
    I'm going to pick a car up early next week, if you still got it after then I'll get it from you!
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Quote Originally Posted by Fast-Tech
    yea just let me know.
    again
    stillllll got it.
    bumpage
    again.
    $120 anyone.
