Results 1 to 25 of 25
Thread: MTX Dual 12" Sledgehammer Enclosure and Thunder Elite 1600watt Amp
    02 WRX patrick4588's Avatar
    warner robins
    Default MTX Dual 12" Sledgehammer Enclosure and Thunder Elite 1600watt Amp
    I WILL BE IN ATLANTA WEDNESDAY THE 22ND to meet up!!
    MTX sledgehammer 7500 series:
    RMS Power : 800W
    Max Power : 1600W
    Impedance : 2Ohm
    Frequency response : 38Hz - 150Hz
    Sensitivity : 96.3 dB/1W/1m
    Woofer diameter : 2x30cm (12¡¯¡¯)
    Xmax : 17mm
    Dimensions (HxWxD) : 36,2x87x45,7cm
    High output MTX Sledgehammer Enclosure
    Vented enclosure with T7500 superwoofers
    2 ohm impedance, optimised for use with a class-d amplifier
    Carbon filled expanded polypropylene cone with aluminium deposit
    Butyl rubber surround
    Stitched cone to surround
    Spider Plateau Venting (SPV)
    Asymmetrical Linear Drive System (ALDS)
    Congruent Edge Technology (CET)
    Unique slot port design
    designed to deliver loud and accurate bass
    Internal wiring from Streetwires
    Thunder Elite 801D Specifications:
    # OF CHANNELS 1
    CLASS D
    POWER SUPPLY Semi Unregulated MOSFET
    (Pat. No: US05598325) x
    THD + NOISE (1 Watt) ¡Ü.5%
    FREQUENCY RESPONSE (-3dB) 20Hz-200Hz
    SIGNAL-TO-NOISE RATIO (1 Watt) 70 dB
    OVERLOAD PROTECTION
    THERMAL PROTECTION
    14.4VDC POWER 4 ¦¸ 400w rms
    2 ¦¸ 800w rms
    Peak Power 1600w
    BI-LEVEL INPUT (RCA Connection) Low Level
    Hi Level w/ Smart Engage (Pat. No: US06556683)
    INPUT SWITCH Input Sense 100mV-1V/1V-10V
    GAIN CONTROL MONO - 100mV-10V
    CROSSOVER LOW @ 40Hz - 200Hz, 24dB
    SUBSONIC @ 30Hz, 12dB, Defeat
    EQUALIZATION QUASI Parametric: Boost/Cut ¡À 12dB, Freq. 30Hz-80Hz
    OTHER FEATURES Remote Subwoofer Level Control Parallelable
    Prizm EFX With Demo Mode
    POWER CONNECTION 4 Gauge Direct Input With 8 Gauge Direct Cap Input
    DIMENSIONS Height 9-5/8"
    Width 16-11/16"
    Depth 2-1/2"
    this is not a cheap setup by any means, and if it doesnt sell for the price i want, ill just keep it. im asking 500 firm. the amp alone retails for 579.99 on crutchfield.
    http://www.crutchfield.com/S-a...E801D it will come with power and ground wire with fuse holder. im keeping the rca's and remote wire for the new system. here are pics with it in my integra. ive had it for about 6 months, but i just got my car running so its only had about a month of use.
    GCO Member
    NRA Member
    warner robins
    someone jump on this.
    GCO Member
    NRA Member
    C.r.E.a.M MistaCee's Avatar
    Work
    Looks like a bumping setup. Bump
    warner robins
    ttt
    GCO Member
    NRA Member
    warner robins
    bumpity
    GCO Member
    NRA Member
    warner robins
    shakes the remote out of the pocket on the door panel, someone needs some bass
    GCO Member
    NRA Member
    warner robins
    still in the car, so you can hear them before purchase!!
    GCO Member
    NRA Member
    warner robins
    half off ppl, only used for 2 months!!!
    GCO Member
    NRA Member
    warner robins
    bumpity
    GCO Member
    NRA Member
    warner robins
    back up bitches
    GCO Member
    NRA Member
    warner robins
    ttt
    GCO Member
    NRA Member
    warner robins
    back up
    GCO Member
    NRA Member
    Warner robins ,Ga
    trade for the frontend?
    warner robins
    nah, ill trade some other audio stuff. i got a few sets of subs/amps/ wiring. hit me up tomorrow and we'll talk. i need to sell this set though; its currently in my car now
    GCO Member
    NRA Member
    warner robins
    back to the top. will separate for 350 each
    GCO Member
    NRA Member
    warner robins
    need to sell so i can order my new stuff. 600!
    GCO Member
    NRA Member
    warner robins
    price drop to 500
    GCO Member
    NRA Member
    Sep 2008
    so 500 for the whole setup? subs amp and everything? or what?
    warner robins
    back up
    GCO Member
    NRA Member
    Out in the Boonies
    hmm ... I think my rear windsheild would shatter with the setup ... lol jk .
    glws
    warner robins
    mine hasnt yet, but it did rattle the hatch plastics off
    GCO Member
    NRA Member
    warner robins
    ttt
    GCO Member
    NRA Member
    warner robins
    someone needs some bass!!
    GCO Member
    NRA Member
    warner robins
    back up
    GCO Member
    NRA Member
    warner robins
    bump. I WILL BE IN ATLANTA WEDNESDAY THE 22ND, someone get this
    GCO Member
    NRA Member
