If you're interested in something, make an offer!![]()
red Z32 front calipers and 5-lug drilled/slotted rotors - $300
CIRCUIT SPORTS rocker arm stoppers, new - $65
Megan Racing 30mm front sway bar for S13/S14, used, no brackets - $100
Megan Racing equal length exhaust manifold NEW - $150
Megan Racing NEW S13 adjustable tie rods - $90
FMIC - 2.5" inlet, 30.5"L x 11"H x 3"D - $80
stock KA clutch/flywheel/pp - $75
stock S14 wing - $25
180SX front brake calipers, Brembo drilled rotors (slightly bigger than stock S13 - 11" rotor vs. 10" on S13) slightly used, durrrty - $200 obo
S14 diff w/ Kaaz 2-way LSD w/ less than 100 miles - read:: this is the S14 housing w/ bushings trimmed to fit S13. The rear cover is for S13, so if you have a S14, just change the rear cover from your pumpkin: so basically, whether you have S13 or 14, you can use this diff. -$700
Spal fan harness for electric fan - $45
Spal electric fan.. 16" new - $110
S14 foglights - $50
New BC valve springs and retainers for SR - $225
Freshly painted S13 SR valve cover, red - $50
Hope someone can use some of this stuff!![]()
