Results 1 to 17 of 17
Thread: List of things for turbo set up
    FLOSSIN' MR.EM1's Avatar
    Default List of things for turbo set up
    Ok guys im about to buy a turbo and an LS swap. Question is WHAT ARE ALL THE IMPORTANT THINGS NECESSITIES TO RUN MY TURBO SET UP????
    I (will) have:
    -b18b
    -b16 tranny, ecu, harness
    -turbo kit wastegate, bov, turbo, IC (piping), boost gauge, afr gauage,
    -going into my 99 EM1
    -OBD2
    -injectors
    -fuel pump
    -oil lines
    do i NEED a different ECu?? turbo timer? intake manifold??
    FL
    02 WRX patrick4588's Avatar
    warner robins
    Quote Originally Posted by SiFOSHO
    -b18b
    -OBD2
    -injectors
    -fuel pump
    -oil lines
    you will need a wideband, a regular afr gauge is gay and wont tell you anything. you need a new ecu definitely, and a tune. will need to convert the obd2 to obd1. you dont need a new intake manifold or turbo timer. doesnt sound to me like you have done much research yet.
    GCO Member
    NRA Member
    yup
    clayton county
    as cheap as a turbo timer is, get it. it will help keep your turbo alive longer by letting the oil cool down and not quickly seize up in the turbo
    I give out reps....
    N/A POWAH! Gorilla Eg!'s Avatar
    listen to the man!!!!!!
    1. obd2b-obd1 conversion harness from www.boomslang.us
    2. socketed/chipped ecu from me
    3. tuning from me
    4. don't bother with the afr gauge unless you want to drop some coin on a wideband
    5. don't bother with the turbo timer either unless you plan on boosting right up to the point you park the car and shut it off. the turbo-timer allows you to idle the car for 1-2 min once you park. if you don't drive like a mad-man and are just cruising for a couple min before you park and shut off the car you're ok. i've been running the same turbo for over 5 years and over 75k miles and don't have a turbo timer.
    I (will) have:
    -b18b
    -OBD2
    -injectors
    -fuel pump
    -oil lines
    off the top of my head, downpipe, i would get some type of fuel management, exhaust manifold, maybe a fuel pressure regulator.
    warner robins
    i dont run a turbo timer. after making some boost pulls, just cruise at low load and that will sufficiently cool the turbo.
    GCO Member
    NRA Member
    Certified Gearhead ILLSMOKEu's Avatar
    Sandy Spring
    Thats my list of stuff that i got on my car for turbo
    Turbo
    Turbo Manifold
    waste gate
    Turbo timer
    Boost controller
    oil line
    Injectors
    Flex pipe
    Intercooler
    Intercooler piping
    hi flow cat(Optional)
    p72 Ecu
    OBD2 to OBD1 conversion
    silicon couplers
    4bolt flange
    tbolts clamps
    flange for wastgate
    Blow off Valve
    muffler 3"
    rezinator
    map sensor
    waisgate spring
    exhaust wrap
    full exhaust 3"
    sparplugs (optional)
    oil catch tank
    New radiator (optional )
    there might be few more thing that i forgot right of my head,so think about what u really need...
    warner robins
    clutch
    GCO Member
    NRA Member
    I (will) have:
    -b18b
    -OBD2
    -injectors
    -fuel pump
    -oil lines
    ***The Forced Induction Forum FAQ Thread-Turbo Size, Injector Size, Turbo Manifold***
    1.5T AnTi-PooN's Avatar
    L'villE
    you dont want a b16 tranny either
    YEAH! bRiAnMcIvIcS's Avatar
    Possibly a:
    Skunk2 intake manifold, Edelbrock 65mm throttle body, and Skunk2 Megapower R 2.75 inch cat-back exhaust.
    the county
    everything you need to know.
    center field
    warner robins
    why did you bump this thread? fail
    GCO Member
    NRA Member
