Thread: Small motor help
    IA's Instigator
    Statesboro
    Default Small motor help
    I have a 5hp honda motor, ive ran the piss out of it and bought it from a guy that had it from the early 1990's or something. It wont full crank, about once every hour itll crank up but only for about 3 seconds then it dies off. I replaced the air filter, changed the oil, and put a new sparkplug in it. still nothing. The head is leaking oil. What else may be the problem?
    (Its a kart motor.
    i dont know much about them but it could be the ignition stater
    Stang Mod slostang's Avatar
    Southside
    I can't imagine a used 5hp Honda motor selling for over $100.
    yeah there about 130 new....But might be in the carb
    SwiperNoSwiping!!
    either that, or an air leak somewhere on the intake tract....Those small motors are notorious to tend to somehow ALWAYS get an air leak and make startup a living he11. I.E., replace all gaskets...
    u remind me of a wigger !
    IA's Instigator
    Statesboro
    ****, its really a 5hp briggs and stratton. i dont know what iw as thinking last night.
    Don Mon SiRed94's Avatar
    Morrow 30260
    uhm about the only way that engine can leak oil from the head is if the rings are broken... do a compression check on it... just pull the plug out and put your thumb over the hole and then pull the string... if it blows your thumb away its good if not they are probably gone....
    Grease Monkey JBizzlebone's Avatar
    Stockbridge
    I'd check the carb first. It might be a good idea to pull it off and rebuild it. The kits are like 10 bucks.
