Thread: So my speedometer is fucced
    Duluth, GA
    Default So my speedometer is fucced
    when I turn my key it goes straight up to twenty and stays there no matter how fast or slow I am going. But sometimes it decides it wants to work properly and just shoots up unprovoked to the correct mph. then without warning it will just drop back to twenty. No what I am asking is...would this be a speed sensor problem? because some have told me it could be that my cluster is just bad? but I took that out and the needle seems to move fine and all that so I am thinking speed sensor but I wanted some other opinions before I go out and spend my money on the wrong part.
    turbos
    I think if it was the speed sensor you would read 0 not 20. get a speedo from and friends car and plug it up it see if it works if it does than ur cluster is bad. if not could be a bad ground or speed sensor.
    TOO BIG
    Where Am I
    let us know cause my girlfriends accord does the same thing, half the time it works and the other time it just sits at 20 mph......
    >.> rizzler's Avatar
    Decatur/Emory
    my rpm meter does that... or it just goes up from 1 to 2k then 3k ... or it just sticks at 2k. :/
    92' Specialized Rock hopper
    04 Civic EX
    loose connection
    Senior Member mikesEK's Avatar
    over yonder
    x's2....but get/barrow another cluster ,seems it's be easier than swapping the speed sensor
    Quote Originally Posted by Benefit
    loose connection
    PawnShopMike
    I miss-spell big words freeqwentlee thanks Dekalb Co skhool systems
    Southside Ridin HATCH
    speed sensor
