Thread: S13 problem
    NW, GA
    Default S13 problem
    OK i have a 92 240sx coupe with the stock KA24DE. Its n/a all it has is a intake. Its having problems accelerating it just doesnt want to accelerate. I thought maybe the fuel filter was clogged so i changed that but it didnt help. It has a rough idle as well. It also has straight pipe exhaust all the way out the back which im sure isnt helping but i just got it today and i will soon change that. So any help is appreciated
    Certified Gearhead Nissangeek's Avatar
    Smyrna
    TPS, injectors, bad gas, clogged intake, could be lots of things.
    It's a 240
    Earth
    It's a 240
    tr00f!!
    polar bears toenails
    Kicking rocks
    lol^
    Grease Monkey JBizzlebone's Avatar
    Stockbridge
    I'd check the timing before anything else. KA's are notorious for jumping timing once they've got some miles on them. First test it with a timing light and try to adjust it by turning the distributor till the mark on the crank pulley lines up with the pointer on the timing cover. You'll want to set it at 20 degrees BTDC.
    JDM TYTE AnthonyF's Avatar
    ^since it is pretty easy to check the timing, do that. Check your plugs too. Maybe your TPS sensor (if Ka24's have them).
    -Ant.
    The Carbon Fibered R6
    Athens/ATL
    Make sure your MAF is reconnected correctly, and that ALL intake holes are either connected to hoses or plugged. My KA24DE S13 was bogging for a while after I installed the intake.. there was a little place on the bottom of the intake for another hose to plug in, and there was no hose for it (the intake is for an s14). The un-accounted for air was making her bog. Plugged the hole with some JB Weld and now she runs like a top!
