Results 1 to 27 of 27
Thread: GSR Recommend Oil
    <--- RIP :,( psycho_freke's Avatar
    Locust Grove
    Default GSR Recommend Oil
    I know this has probably been asked a million times, but with the word oil being only three letters and used so often, my searches are coming up with nothing helpful. I know that Acura only recommends a basic 5w30 blend of motor oil, but I also know that there are some guys on the forum who have their engines apart often and frequent the performance shops with experience using different oils. What kind of oil would you recommend using in a nearly stock '96 GSR?
    Augusta, GA
    I use 5W-30 for my gsr motor..
    Locust Grove
    Quote Originally Posted by b17a1db2
    My question isn't really a matter of viscosity, but rather a question of brand/type. High mileage, synthetic blend, full synthetic? Castrol, Valvoline, Royal Purple, Mobil, etc.?
    Stang Mod slostang's Avatar
    Southside
    I would use 5w-30 mobil clean 5000
    Ive ran fossil oil castrol for years and years, its great oil.
    Augusta, GA
    Quote Originally Posted by psycho_freke
    i was using conventional castrol gtx, but now i'm using Mobil1 synthetic.
    한 국
    10w-30 mobil 1 & oil filter
    Middle, Ga
    None better than Lucas! < Very good stuff and expensive....lol
    "Damn, Its Tyler"
    RaceReadyDevelopments
    i use whatever it says on the oil cap to use. ill either us mobile 1 or mobile 1 full synthetic.
    Senior Member Schugg's Avatar
    i use all honda/acura genuine oil from the dealor
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    Locust Grove
    sooo.... some pple use synthetic on their GSRs, and some don't. Do you really notice a diff in how the car runs using the synthetic, because from what mechanics have told me, you're still supposed to keep with the manufacturer's recommended service intervals regardless of the oil you use due to the fact that it isn't the oil that wears out that causes you to have to replace it, but the debris that are suspended in the oil that need to be cleaned out of your engine.
    Middle, Ga
    A buddy of mine has a built single/vtec and he has been running Lucas synthetic from day one, cause the guy that helped build the motor told us it was a good oil to use on any type of a built motor.
    "Damn, Its Tyler"
    Synthetic oil isnt necessary for a street vehicle. It doesnt extend your oil change interval because carbon from the combustion process contaminates synthetic at the same rate that it does with fossil oil. Key with any oil is maintaining a 3k-5k oil change interval along with filter.
    Athens/ATL
    on my GSR sol I ran Redline 10w30 synthetic. When I moved to Savannah and they didn't seem to know what the hell that was, I switched to Mobil 1. Changed every 3000 miles religiously.
    Locust Grove
    That all depends on the vehicle. I know that some of the newer cars call for synthetic, although I don't remember which. I think some of the new Acuras do if I remember right. I just remember that from working at Pep Boys. However I was also told by a few mechanics that it was unnecessary to use synthetic in a vehicle unless it was built for performance, or called for it from the manufacturer. Seems most pple on this forum are using synthetic, though.
    Alot of times though an oil company will get in cahoots with a auto mfg and work out a deal to specify for synthetic. Mobil and BMW have done this. Its not like if you put fossil oil into a BMW it will start knocking.
    Locust Grove
    After reading an article on team-integra.net I decided on Mobil1 0W-30 full synthetic Here is the article:
    http://www.team-integra.net/forum/di...urnPage=Search
    02 WRX patrick4588's Avatar
    warner robins
    i posted that on gategs a while back. i was getting ready to post it here . i rock
    GCO Member
    NRA Member
    Athens
    When I had my Si, i used Royal Purple 10w30. Now in my dsm I am using Mobil 1. Good Stuff.
    Marietta, GA
    Royal Purple is definitely some good oil. It's pretty expensive in most places though. I use Mobil 1 5w30, but 10w30 will work just as well. It doesn't get too extremely hot or cold around here so weight won't really matter. My philosophy behind it is, if the synthetic stuff is rated for twice the mileage then you will definitetly be protected up to 3K miles reguardless of how you drive.
    Turbo-Wired
    East Cobb
    Mobil and BMW? BMW rec's Castrol on most of their caps for synthetic, but developed their own specifications for their full-synthetic requirements in Germany with ELF. ELF is probably the best Synthetic you STILL can't seem to buy in America, and one of the best oils available on the market. Regardless, no oil in a car is going to make it start knocking, not the kind of oil in it. The problem with putting conventional oil into a BMW is that the seals and filter are actually designed specifically for the minute differences in how synethic acts in certain conditions, combined with the fact that the BMW's need extremely high levels of protection for their 11.5:1 and 12:1 comp ratio engines.
    To that end, if you ever put conventional in a gas-powered turbocharged car, you are BEGGING for trouble. Synthetic oil doesn't coke up like conventional oil does, which is a neccessary property when you've got an oil cooled turbo.
    Augusta Ga
    use mobil 1 full synthetic 10w-30 with lucas oil stabilizer ... u wont go wrong ..... all ive evered used in any motor ... honda or not ....
    93 sol Si
    95 sol S
    95 sol Si
    Locust Grove
    I've never used the lucas. A lot of pple say it's good, but I don't like to use additives if I don't have to (and yes, the engines in all of my cars are very clean and run very well without it).
    Augusta Ga
    i use it but thats me i know there is a difference with and without it .... but yea i know you dont NEED it .... but i like using it its like a insurance if thats wut u want to call it ...
    93 sol Si
    95 sol S
    95 sol Si
    Marietta, GA
    lucas is good if you have some rocker noise or a tick somewhere, also if you pull the drain plug and find excesive metal deposits. i've heard people say they don't like the stuff, but every case i've had to use it in it has worked like a charm. it won't necessarily fix the problem, but it can put it off for a long time.
    Hiawassee, GA
    I always ran Mobil 1 5W-30 and the smaller size HAMP filters, changed at 2500 miles religiously.
    Lucas is good stuff, but I don't use it in any OHC motor, its thick stuff and doesnt circulate as easy. I'm sure it wouldnt hurt them, but I never tried it. Good stuff to stop a small tick, or even a very small leak.
    -Zach-
    1987 Toyota Pickup - Toy
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    just use some regular 5W-30 (castrol is what we use at the dealership) and a honda filter. no need to put synthetic in there, because the motor has mileage/ it will most likely burn through synthetic quickly, and it will create leaks.
    Who knows?
