This is for people that only know the Zs.. I know cars but not issues with Zs that could be casuing this.. I do know of EGR issues with it clogging. I just figured some of the Z1 guys where on here and could teach me a thing or two about these things.
To start things off I failed emissions... I used to be an inspector a long time ago and here are the numbers below. I am thinking plugs, wires, dizzy cap, injectors, or cat for the HC (HC = unburned fuel)
For the CO I was thinking O2, breathers, air filter (clean), PVC Valve, or vac leaks because the CO is air flow through the engine.
The NO (Nitric Oxide) that has to deal with Cats, O2, EGR, injectors, and cooling is the main things to look at when failing the NO because it has to do with when the engine is under load and is hot...
My point is that I am thinking I will since the NO passed I should take a look only at the plugs, wires, PVC, breathers, due to the things that have passed makes me think eliminate those things from the HC and CO and check the other things.
25/25 Test
Reading Allowed
HC ppm 00153 00117 FAIL
CO % 1.78 0.65 FAIL
NO ppm 0028 00821 PASS
50/15 Test
Reading Allowed
HC ppm 00163 00120 FAIL
CO % 3.27 0.67 FAIL
NO ppm 00044 00907 PASS
			 300ZX emissions questions...
