Results 1 to 31 of 31
Thread: 300z bbk installed on an ALTIMA
    Glock 357 sig pipeline's Avatar
    Villa Rica
    Default 300z bbk installed on an ALTIMA
    for everyone who does not know what BBK means....
    Big Brake Kit
    there is a guy over on maxima.org who sells a bracket to install 300z tt 30mm calipers on stock +04 maxima rotors
    Welcome To BlehmCo
    since SE-R rotors and calipers are the same as +04 maxima.............
    i needed to do front and rears so,
    slotted and drilled front and rear rotors from rotorpros.com
    bracket and front 300z SS lines
    +04 maxima SS lines (rears are longer than ours)
    since I wanted to keep my SE-R setup and not paint it, I bought a set of rear calipers.
    Now, all 4 calipers I bought came "fully loaded", meaning pads were included.
    Amsoil DOT 3 brake fluid.
    This project took me alot longer than I thought it would. I am not savy on brakes...I mean i can swap rotors and pads....but the ss line changeout was... annoying...a pain... grrrrrrr
    and lets not get me started on bleeding brakes...:banghead:
    Villa Rica
    Certified Gearhead KlassAct_EJ6's Avatar
    Cincinnati
    I can dig it.
    Dunwoody
    looks good wouldn't call it a BBK necessarily though.
    Im French! Frög's Avatar
    AMERICA FUCK YEAH
    damn thats pretty cool!!
    Middle, Ga
    Adding performance and a great look, I love the look that the rotors give behind the wheels.... goodjob bro
    "Damn, Its Tyler"
    RaceReadyDevelopments
    lawrenceville
    now that is using your head upgrade brakes before going faster
    cause later it might be to late
    FYCN in a rick james voice
    Rockin' the DA Blownb18c's Avatar
    Macon, Ga
    nice nice--way to put the work in
    New W.I.P. = 06 Civic SI :-)
    Villa Rica
    300z calipers are 4 piston.............
    how is that not a big brake upgrade?
    91Z32TT
    Kennesaw, GA
    Cause i have a 300zx and i did a BBK other day with 13" rotors :-D... So yes 11" isn't really BBK but it is a nice upgrade. Looks great btw.
    Villa Rica
    my rotors are 12.6 in...............
    haha!!
    i could have used the braket jeff makes for the 13 in cobra rotors... but i figured i had pieced together alot already
    i see your point... it is an upgrade to me though....
    Your mom's bed
    wat a proect like this run u with everything? my buddy is looking for the same setup.
    Villa Rica
    Quote Originally Posted by 00CelicaGT
    depending on how cheap you can find things...
    +04 maxima rotors/SE-R altima front rotors are the same thing $100 or so
    300z tt 30mm calipers... $100-$200
    bracket and SS lines $200
    i needed to do my whole setup...
    rotors for me on all 4 corners were $200
    you can find rear SS lines for $45-$50
    if you have the rotors already, you could piece this together for as little as $300 (fronts only)
    i did my whole setup for about 7 bills (and that was replacing EVERYTHING)
    Your mom's bed
    damn thats pretty good. ill have to tell my boy bout ur setup thanx. +1
    Weekly Gwinnett/Junciton Meet
    nicely done, but calipers don't cover the full rotor surface? I see a good bit of gap.
    Torque is love.
    Charleston, SC
    Quote Originally Posted by UpSideDownDesi
    Yeah, that area with no pad contact is essentially just wasted unsprung weight.
    Regardless, the setup looks T!TS.
    Absinthe makes the farts go Honda.
    Quote Originally Posted by MSRTom
    hence no performance gain by rotors other than loss. Going looks wise setup looks awesome.
    Looks great
    STREET<3LOVE DoriDori's Avatar
    North Georiga
    Great job!!!
    XXXXXXXXXXX therealgoon9's Avatar
    Matt makes good stuff I need to order some brakes lines from him when I get unbanned from the .org...
    Villa Rica
    not sure what to tell you... those pads on the 300z calipers are bigger than my stock pads..
    there is a difference in braking.... believe me...
    you been making me think about this.........
    i just did some searching and the maxima guys are all the same... the lower section of the rotor looks like mine..
    Villa Rica
    Quote Originally Posted by therealgoon9
    Matt makes good stuff I need to order some brakes lines from him when I get unbanned for the .org...
    we all get banned from time to time.......
    True, but it will also dissipate heat better, and the bigger radius will give it more stopping power regardless.
    Quote Originally Posted by pipeline
    that's DEF better than what you had, but that setup isn't up to it's full potential. As you can also see there is unused rotor, and this is very common when you piece your own BBK. None the less better than before. Is there any more more room between the caliper and end of the rotor?
    BOOB koukis14's Avatar
    Pennsyltucky
    I had those brakes on my S14. That thing stopped on a dime. Looks good. I would be interested to see if you could get the Brembos on the last gen SER to bolt up.
    Smyrna, GA
    those are not 300zx rear calipers, just so you know. In case someone sold them to you as 300zx rears.
    Villa Rica
    Quote Originally Posted by nsany(atl)
    they are altima/maxima stock rears...
    these are 300z rears..
    Villa Rica
    Quote Originally Posted by koukis14
    non brembo z rear calipers/rotors bolt right up.
    the front brembos do bolt up with some modification (slight)
    z32 power thursdaybuff's Avatar
    Lawrenceville/Snellville
    Looks good man. I'm probably about to get rid of mine for some upgrades if anyone wants mine.
    Villa Rica
    Quote Originally Posted by thursdaybuff
    26mm?
    30mm?
    iron? aluminum?
    fronts only?
    rears?
    INFO!!!... i might be able to help you get rid of them...
    26mm?
    30mm?
    iron? aluminum?
    fronts only?
    rears?
    they'll be the 30mm rotors and aluminum calipers, could be front and rear but i'm not sure yet, still gotta save up a little more. i guess it'll be whichever i get a better deal on..
