Results 1 to 26 of 26
Thread: Rc 550 injectors in a Stock engine?
    theConclusion
    Stone Mountain
    Default Rc 550 injectors in a Stock engine?
    Ok, digg this... I inherited some RC 550 injectors. I want to put them on my 96 Integra LS which is mostly stock. I just dont know if it's a good thing for the engine or bad. What's you all's opinion on the matter?
    Do you even know what they do?
    theConclusion
    Stone Mountain
    Quote Originally Posted by 81911SC
    Yeah I do, they came off my 94 boosted LS...but at the same rate Idk about them being on my stock motor. I don't want to be hard headed and put them on and something happens.
    Hwy 315
    Quote Originally Posted by BlacKalypso
    if you inherited them, how were they on a car you already owned in the first place? (your boosted 94 LS)
    at any rate - what is the point of running something that big on a stock engine? It's stupid and you shouldn't do it. Don't even waste your time installing them when you don't need them.
    Better yet - take the turbo kit off your boosted LS and install it on your other stock LS. Then you'd have good reason to put the 550s on there.
    *sigh*
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    theConclusion
    Stone Mountain
    Quote Originally Posted by se7en
    *sigh*
    -jonathan
    I inherited the whole car. Its just a problem with time and distance as far as the boost kit. All my parts are in VA (at school) and Im home. But it is what it...Ill figure it out. And thats what I wanted to know. If I needed them or not... I appreciate it
    u dont need them. youll do more harm than good with them.
    Hwy 315
    not a problem sir!
    -jonathan
    [/URL]
    Around metro-ATLANTA & IA!!
    when did u wake up!? gas is $4+ dollars a gallon buddy, are u
    just listen to what "se7en" said and you'll be straight.....
    my turbo is bigger! revsk8erdude's Avatar
    Blairsville
    for real dude, gas is too damn expensive to piss away like that. it wont even cange any HP ratings either. its useless.
    enjoy the MPG's!!
    WTB: My own forum, so I can badmouth IA.
    IA Member wanksta's Avatar
    powder springs, GA
    your stock injectors can make 50hp more than your engine is making. i'll buy those 550s if you dont need em
    N/A POWAH! Gorilla Eg!'s Avatar
    Quote Originally Posted by pxhoang0408
    NO SH*T!!!! bigger injectors = more fuel = worse gas milage = MORE $$$!!!
    PLUS bigger injectors on a stock motor are pointless
    unless you're planning on tuning for the larger injectors it's pointless like has been stated above.
    the are useless to you....but on the other hand, my sc could use them, how much you want for them?
    theres no point in using those injectors on a stock motor. unless you plan on boosting i would not use the 550cc. even if you had all the basic boltons and some, 550's would still be way more than you need.
    wow, this noob neg repped me 'a little late there buddy'. lol, grow up. trying to give my .02 cents.
    Canton, GA
    Quote Originally Posted by watdaflo?
    Actually, injectors for those cars have always been undersized from the factory. I say going with the 550's will give you a good boost in power. Let us know how it feels when you get those on.
    Quote Originally Posted by Neon Nick
    o, i never knew that. so how much more power can i get with a stock car just by putting bigger injectors? can i buy like 750cc for more?
    Yeah, in general the higher the cc the more power and the first two numbers are how much power you're adding (like shots of nitrous). So 550cc would add 55hp, 750cc would be 75hp, etc.
    i learn something new everyday. and there reletively cheap too. i love this forum!
    That's what it's all about, helping fellow tuners out!
    Jan 2003
    Please, please, please.....don't give out any more "advice" like that. It is 100% incorrect. That "formula" is something that I've never even heard of before, let alone correct.
    Adding bigger injectors to a STOCK engined car brings up several problems:
    #1. How is the stock ecu going to control those bigger injectors? Simply dropping in injectors that are almost twice as large as stock is not going to do anything but not let the car run at all. The ecu doesn't have the proper map nor capabilities to do that. So it will try to run 550's like the stock 240's, which doesn't work. Not now, not ever.
    #2. "Power" is a combination of both fuel and air. Yes, more fuel equals more power, but ONLY WHEN more air is also introduced. So if you just dump a bunch more fuel, even if #1 above would let you (which it won't), then you're not going to make ANY more power until you dump in more air accordingly. So just putting in bigger injectors is NOT going to net you more power. Not 55 hp, not 5 hp.
    Out in the Boonies
    Lol i bet you're serious too...
    Flowery Branch
    not even going to chime in on this one...
    Senior Member G.C's Avatar
    Forgot
    useless thread. delete it please.
    :idb:
    I promise it's stock
    Atlanta-ish
    This thread has some of the worst info ever.
    OP, go to www.rceng.com and read through the FAQ.
