Thread: diy jdm itr conversion
    Default diy jdm itr conversion
    ok, i looking into getiing the conversion and i want to install it my self. has anybody dont this before. easy or hard. any references were i can go to find out how its done.
    clayton county
    remove entire USDM front end, using drill bits.. drill out all of the spot welds that hold on the stock core support, remove the support and cut a little bit on the sides of the stock frame to make room for the bigger JDM headlights. test fit the new support and make any necessary adjustments to make it fit good, then bolt or tack weld it into place using ALL of the spot weld holes. bolt up the lights, fenders, hood, latch, JDM bumper support, bumper and you should be good.
    I give out reps....
    beat me to it
    the old man NAIZBST's Avatar
    I did mine myself and it is not hard..... khaxnguyen explained it
    ANDREW AKA DEAF GUY 404 THE DC4's Avatar
    southside
    Do we have to take exhaust maniford off the motor before swap jdm front end, right?
    NIKON Squad member 05
    Mah shit thread
    clayton county
    Quote Originally Posted by 404 THE DC4
    no you dont, in many cases you dont even touch the motor or any part in relation to the engine running
    I give out reps....
    RE30
    just the radiator and ac. but he got it about right. gl buddy dont mess up bc that would suck real bad
