Results 1 to 14 of 14
Thread: need help with my LS
    Certified Gearhead 93delsol15's Avatar
    tennessee
    Default need help with my LS
    how much hp would you consider to be safe on an ls bottom end
    I want to do a an all motor build
    I was thinking of doing a full head job, like port polish , cams and valve train
    i am also thinking of doing boost on the stock bottom end
    does any body have any ideas or suggestions on how to make good, reliable power with out building the bottom end
    d15b7 fs 300obo has to go soon
    YEAH! bRiAnMcIvIcS's Avatar
    You should be safe turbo'd with around 230whp(not much more than that), just get a good tune. You might wanna upgrade the valve springs and retainers but thats all the headwork i would do.
    Good Luck
    02 WRX patrick4588's Avatar
    warner robins
    all motor ls build. lirl. definitely turbo it
    GCO Member
    NRA Member
    tennessee
    ok a turbo sounds like a decent idea i just dont like it when a turbo spools so late in the rpms so what will i need for a quick spooling turbo set up
    warner robins
    smaller turbo's spool faster, but run out of breath up top. since you have an ls, you dont have a high rpm you need the turbo to stay til. without knowing your goals or budget, ill just throw a t3/t4 50 trim out there. should spool pretty quick and make good power
    GCO Member
    NRA Member
    tennessee
    i want like 200-220 at the wheels and after that i will probably build the bottom end and go for high boost set up
    boost the ls going all motor on a ls is just wasted money.
    tennessee
    is 200 at the wheels a pretty easy goal in an LS
    Quote Originally Posted by 93delsol15
    Yeah sure why not, that's about 70 more WHP than you have right now. But don't expect a stock LS to handle much more than that.
    you can get 240whp pretty easily with a properly tuned LS with some boost! id go with a smaller sized t3 and have a nice powerband.
    tennessee
    thanks guys
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    x2
    is 200 at the wheels a pretty easy goal in an LS.
    Yes IMO, I think ideal.
    I would say 200whp is safe. Anything over that isn't.
    GT2860rs(garrett) would be a good turbo for you.
    tennessee
    wow i have never heard of that is it a good size and would it be better than the volvo turbo i am getting
