Results 1 to 14 of 14
Thread: Okay, done research..found nothing on the Apex'i VAFC2.
    SwiperNoSwiping!!
    Default Okay, done research..found nothing on the Apex'i VAFC2.
    What are ALL the features that the Apex'i VAFC II includes?? I know its for fuel map, wide throttle, narrow throttle, low cam, high cam, can tell the engine when to switch to vtec, aaannnd.......... What else?
    Can it tell oil psi? Im about to go buy an oil psi gauge separately if this thing cant read oil psi....
    u remind me of a wigger !
    SwiperNoSwiping!!
    Also, should i spend my money on an APC oil pressure gauge? How accurate are they? Is it worth dropping $30.00 on? lol.... I'd really rather have another Autometer Ultra-Lite but my funds are somewhat low right now....
    just go to autozone and buy one of there brands. thats where i go for mine and there's are pretty accurate and they cost like 15 or 20
    SwiperNoSwiping!!
    Quote Originally Posted by bouncy!
    I didnt know Autozone had its OWN brand of gauges? Ill probably have to go check that out
    Senior Member | IA Veteran Mad Mike's Avatar
    Gainesville
    Quote Originally Posted by GM_TUNER
    Autozone sells autometer, sunpro and faze gauges.
    VAFC does VTEC control, MINOR Fuel adjustments, low cam and high cam.
    TO be honest it sucks. I only recommend it if you are doing I/H/E an THATS IT. Its good for OBD2 guys that dont do alot of mods an want to still be able to pass emissions.
    If you are OBD1, its a waste, you can pay me or scotty to chip your ECU for the cost of a VAFC an have a fuel an ignition tunable ECU versus a piggyback.
    VAFC Only displays
    RPM
    MAP VOltage
    TPS VOltage
    THrottle %
    FUel Correction
    SwiperNoSwiping!!
    VAFC Only displays
    RPM
    MAP VOltage
    TPS VOltage
    THrottle %
    FUel Correction
    Ahhh, well.... im doing this on I/E and P+P IM with TB bored out to 61mm.
    ANDREW AKA DEAF GUY 404 THE DC4's Avatar
    southside
    I/H/E -- INTAKE/HEADER/ EXHAUST right? im sorry if im so noob...
    NIKON Squad member 05
    Mah shit thread
    i'm a got dang wallaby!!
    ^^ yes you are correct...
    JDM TYTE AnthonyF's Avatar
    do not get an oil pressure gauge. Your car should have an oil light on it's own. If you do get a Oil gauge make sure it's ELECTRICAL and not MECHANICAL.
    -Ant.
    The Carbon Fibered R6
    ALL CAPS JITB's Avatar
    -Ant.
    i HAD a mechanical oil gauge once...never again!!!!!!!!!!!!!!
    ^and I bet I can guess the reason why. That was the first thing people told me about before I bought my gauges. I have 6 Auto Meter Cobalts and they are ALL electrical. A bit more, but trust me...its totally worth it.
    -Ant.
    Mi6o
    does vafc help improve fuel economy?
    -Ant.
    i forgot to use teflon tape on the connectors...and had a puddle of oil on my floor...
