Results 1 to 10 of 10
Thread: AE86 Garage blow out!
    DRFT
    Marietta GA
    Default AE86 Garage blow out!
    Selling a bunch of stuff that I don't need anymore b/c I'm getting rid of the rolla. Time to move on to something better...like a nissan 240sx.. j/k... Selling everything b/c I dont have the time or money to continue with this project.
    -7 Rib block(bored over half a mm, 4th cylinder needs repair, like a good honing). =Make offer
    -3 Rib block(stock bore)=$50
    -Weisco high comp 10.2-11.8 compression ratio pistons 81.5mm(one has detination on it, but isn't bad at all.)comes with rods on it as well, not even 20 miles on them.=$525
    -4age big port head(injector ports plugged for carb setup. Its been cleaned and milled)=$125
    -Dellorto 40mm carbs & side draft carb intake manifold(Been rebuilt, cleaned, new seals and gaskets with new linkage)=$650
    -OEM brand new oil pump with from main seal=$75
    -Brand new crankshaft=$200
    -New Rod, main, and thrust bearings=$65
    -New mallory fuel pressure regulator (3-12 psi) with guage and hosing.=$75
    -New head gasket.=$50
    -Intake and Exhaust cam with cam gears.=$60
    -Two pairs of valve covers. One set powder coated black.=$15 each. And 30 each for the painted ones.
    -4age stock ecu.=$50
    -4age start with positive wire.=$40
    -Distributor.=$30
    -Two Alternators.=$35 each
    -MAF.=$50
    -Flywheel with bolts.=$20
    -Clutch with pressure plate and bolts( about 50 percent left).=$15
    -Intake manifold.=$30
    -Wiring harness for kouki and zenki GTS.=$ Make offer
    -Driveshaft.=make offer
    -Tranny(second synchro is going out).=$75
    -Good motor mounts.=$25 each
    I am selling a 1986 GTS hatchback(no conversion).
    -Clean title
    -no motor
    -no tranny
    -Comes with LSD
    -Brembo blank rotors(front, about 300 miles on them)
    -Hawk pads(front, about 300 miles on them)
    -Tokico blues
    -Espelier springs(not sure on kg)
    -JIC inner tie rods
    -T3 camber plates
    -Rear sway bar bushing
    -Holley fuel mechanical fuel pump
    -Toms steering wheel
    -Fuel delievery is set up for Carbs.
    -Has dents on the driver side door(can be pulled with a plunger). Passenger side fender is black. dent on driver side fender. no interior(sound detinating material has been removed, i do have carpet though). No seats.
    -Asking 1500 for the chassis
    [email protected]
    aim-i am jacks turbo7
    ''I never had one beer. If I bought a six-pack of beer, I kept drinking till all six beers were gone. You have to have that kind of understanding about yourself.''
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    vouch for seller
    Hachi Representative
    Fayetteville, GA
    Damn it's a shame you're not willing to part with that LSD rear end. Definite bump for the guys looking for Hachi parts. This is a gold mine of stuff I don't need (yet).
    DRFT
    Marietta GA
    yeah i would sell it but i dont have anything to go back in it and I would have to drop the price a little more. Sorry man.
    IA Member GT-S Boy's Avatar
    Lilburn
    emailed you
    FS:new Snap on tools
    I wish i had some cash. glws
    Oct 2008
    nice!!!
    glws
    ifureadthisurgay imbatman's Avatar
    Stockbridge, Ga.
    do u have a picture of that 7 rib block?
    DRFT
    Marietta GA
    I do not at the moment but I am pulling the engine out tomorrow and parting everything down. Will make a new thread will a bus load of pics.
    Stockbridge, Ga.
    awesome. i might pick some couple of stuff from u
