Thread: B16A???????
    THAONLYDAW/SISEATS
    Winder
    Default B16A???????
    i had a b20b in my teg and it took a dump. i was going to use my block and go B20vtec but i was wondering
    Would it be worth it to bore the B16 and use the B20 pistons?
    Ok im ordering a b16 to go b20vtec...my crank is scarred...so what kind of crank should i get to use the b20 rods w/ the b16 pistons but feel comfy revn to 8+
    not really because you would have to resleeve that b16 block$$$$$$$$$
    THAONLYDAW/SISEATS
    Winder
    everyone says you need to re-sleeve...WHY?
    E-Thug SouthSide Tay's Avatar
    SouthSide Atlanta
    stock sleeves are weak and if you bore them you are increasing your chances for failure
    - SouthSide Tay
    93 Sonoma
    -350ci SBC/th350/edelbrock single plane intake/holley 600cfm/dual flowmaster/3.73 rearend/ Weld prostars/ 27x8 Hoosier Slicks
    Daily Driven
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Quote Originally Posted by SX-MAN
    the sleeves are too thin to overbore to a b20 spec.
    Around metro-ATLANTA & IA!!
    I dont even think they make OEM oversized 84mm B16 pistons that crazy!
    OEM B16- 81mm bore
    OEM B20-84mm bore
    U can put the B16 pistons in the B20 block if your goal is to make 0 whp and piston slap yo ass than it can be done!! JK dont do that
    Are u tryin to go High comp. all-motor, if so no OEM B20 piston can help u there cuz i beleive theres only 2 types 8.8/9.6:1 comp, gotta go aftermarket if u want, lets say 10+ comp...
    And why buy a whole B16 if u can just buy the parts u need to make an B20/VTEC( head, headgasket, lines etc. your gonna be spending to much useless money if u buy a whole B16 than part it out take the money that u could've save and put it towards a good tune afterwards
    LS/B20 crank should be the same, they share the 89mm stroke and rods are basically the same
    Maybe the amount to fix your B20 was more than gettin a LS block??
    This would be much cheaper for u in my opinion, so than now u can use many different OEM pistons with the standard bore size(81mm or OS)
    And if u dont have the money to do any of this, dont even try to go halfway and add more stuff later cuz you'll be wasting your $$ when it blows!! Do it the right way man or your gonna have to do it again.
    just my
    Quote Originally Posted by pxhoang0408
    OEM B16- 81mm bore
    OEM B20-84mm bore
    just my
    yah beat me to it.
    off to the RLD i go woot woot.
    gwinnett
    b20-v = ftw.
    THAONLYDAW/SISEATS
    Winder
    Well my teg is my dd i was going to buy the b16 and put it in to get around..while i build the b20...but the b20 crank was grooved so i need a crank...i was just wondering what i could use... im using b16 pistons idk if its going to be the ones in the motor or new with the ls rods..
    im planning on using everything i allready have, i just need a crank and was wondering what would work with the ls rods
    o and forgot... the b20 was run HOT... i mean the exhaust mani was glowing and i could have lit a cig. of off it. so i need new everything... i was just gona by a b16, one to see what the diff is between the 2. and i could just use all the parts and make a b20vtec motor......
    clear your inbox
    THAONLYDAW/SISEATS
    Winder
    cleared.......
    YEAH! bRiAnMcIvIcS's Avatar
    Lol. People usually do b20b blocks with b16a or b18c heads if your going the b20/vtec route. It would be retarded to put b16 pistons(81mm bore) in a b20b block(84mm bore). Just build the block b20b... forged pistrons(84mm bore) and forged rods(Ls/B20b spec)...etc$$$. You may want to resleeve the b20b block if you plan on putting alot of power through it. What do you want out of the motor, boost or N/A? You really need to do ALOT of research.
    www.honda-tech.com is your friend.
