Thread: H22 swap in 96 Hatch
    Ridin Dueces BOOSTED96EK's Avatar
    Macon,GA
    Default H22 swap in 96 Hatch
    i got a 96 hatch with a h22 swap and i need to know if anybody knows where i can find a wiring diagram to wire it up using the stock dx harness.Or do i need to use a different harness with this swap. Im also using a conversion harness and a p28 chipped to run the ecu and i need to know what injectors to run in the engine with this setup. i know i cant run h22 injectors without a resistor box. so any help will be appreciated!!!!
    go to honda-tech do a quick search you will find your answers faster.
    Flowery Branch
    rywire.com
    I can do it ;] i have swapped an h into everything...
    YR88 Win! Romeo's Avatar
    Middle Ga.
    i doubt you could use the stock harness. maybe with some manipulating you could.haha. I.E.-adding wires and such.
    Macon,GA
    The motor is in the car and running. there is just some wiring issues i would like to change. and i think who ever did the swap used the wrong injectors cause i have to jack the pressure up on the regulator all the way.
