Results 1 to 35 of 35
Thread: FS: STS 1989 Civic Si autocross
    iTrack matthewAPM's Avatar
    Otto-Flimm-Straße, Nürburg
    Default STS 1989 Civic Si- SOLD
    SOLD!!
    Engine
    · 150k-ish mile motor from 1989 CRX Si.
    · AEM Warm Air Intake (with heat shield)
    · DC Sports 4-2-1 Header (8 events)
    · Custom stainless 2.25” exhaust, Magnaflow 14” muffler, dumps by passenger rear wheel – will include extra Magnaflow 14”
    · New cat
    · June ’06 – plugs, wires and all engine seals/gaskets replaced. Seems like valve cover is leaking though
    · April '08 - alternator, distributor, belts
    · Underdrive Crank Pulley
    · Tiny 10lb-ish battery – no issues with starting car – have a disconnect wired into negative side of battery because there is something that drains the battery after a week or so of sitting. Also every fuse except the ones that are necessary to run the car have been pulled
    · No AC or power steering.
    · Redshift ECU with 7600RPM rev limit
    · Front/Rear ES Mount Inserts
    Suspension
    · GC/Koni Race Valved/Shortened Shock and Spring combo. New in June ’06.
    · CRX HF Front sway bar with poly endlinks
    · All Energy Suspension Black Poly bushings throughout whole car unless otherwise noted
    · Ingalls rear camber arms
    · Brand new upper control arms/ball joints – rubber bushings.
    · June ’06 – brand new lower ball joints and wheel bearings.
    · Hawk HPS Front pads
    · ATE Superblue Fluid
    · April '08- brake master cylinder
    · Progress Rear 24mm Infinitely adjustable sway bar. Not the three holes like the ST – it’s a slot. the slot was lengthed to make the bar stiffer than what comes from Progress.
    · GPO3 Red Glastic rear sway bar pillowblock mounts.
    · 16 inch kosei K1's with Falken RT-615s
    · Interior
    · Honda factory radio block off plate
    · Driver seat - Corbeau Forza on stock sliders – meets 25lb rule but its damn close. Stock seat for Passenger
    · Cracks/holes in dash (just below gauge cluster) have been repaired via plastic welding and super glue. (very hard to notice)
    · Mount for DL1/DL90 just below emergency brake
    · Grant ‘D’ shaped steering wheel.
    Body
    · 196k-ish miles. Car has been repainted – doesn’t match original red color. Not great paint but looks good from 5 feet
    · Rolled rear fenders – painted over cracks inside fender lip.
    · Driver side rear bumper and front bumper is ugly
    · A little bit of Bondo around rear fenders
    · Front lip included (but not in the best of shape)
    · Radio antenna removed but included; Honda Factory Plug installed.
    · Rear bumper on has half moon circle from where the exhaust shop actually cut part of the metal bumper mount and bumper to run the muffler exit. This is clearly not what should be there, so there is a 2inch cut in the bumper.
    Spares
    · Gutted stock cat (for track events)
    · Stock Si Front sway bar
    · Progress poly rear sway bar bushings and mounts
    · Passenger side upper control arm – brand new
    · 2 Bridgestone RE-01r 195s (50% left)
    · 3 10lb-ish batteries
    · Tranny
    Must be pickup. $5000 firm
    Call anytime 404-455-2784
    New car coming soon...
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    decatur
    good luck matt.
    C.r.E.a.M MistaCee's Avatar
    Work
    You DD this car?! Looks like a fun machine. GL on sale
    Bring The Rain FutureManLS's Avatar
    Cleveland, TN
    Very nice...Gluck on sale
    '93 5.0
    Quote Originally Posted by MistaCee
    Its was driven to and from the events, meets, and a few other times. But thats pretty much it
    Thanks everyone. Hopefully the car gets sold soon.
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    BTW, car will be at the Year One event.
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    seen this car couple of times on 316....!
    car will be at year one event if anyone is interested
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    nice and all but i think 5gs is pretty steep.......
    Santacruz77 the price is just right..
    if you know the kind of prep thats in that car that car is just right. This ain't a street car its a national tour level auto cross car.
    CJ
    Quote Originally Posted by JRDman
    CJ
    guess ive got a national tour level auto cross car too then. wow.
    gl on the sale though.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    CJ
    DAMN FOR REAL
    CJ
    ummm how i see it...Power wise NO.....Suspension wise then YES....anybody could invest all their money on suspension wise and get it ready for autoacross......!
    Scottish Scotsman's Avatar
    on the road to recovery
    seen this car in person , very nice
    Senior Member kaotickaozpunk's Avatar
    hey i dont know if its the same car but i think ive seen this car on the side of the road once on 316...am i right?
    DA SQUAD # 13
    DUH-KYOO-LUHHH
    Quote Originally Posted by Uptown401
    its called prepared for its class moron. you cant have a boosted k20 with 700 hp and still run in sts.
    either way this car is quick. it pulls on my miata and is side by side with type r's, so its not a SLOW car.
    GL matt, i can vouch for this car. BABIED and very well kept.
    about this far.
    bump for the civ
    I♥my ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    Newnan
    its good, but not the best suspention set up...stock motor? if so then 4k is MAX I would think. I had D2's new paint and some bushings and newer upper control arms on my accord and it still didn't make it worth more than 3k with stock motor
    Quote Originally Posted by TR_Accord
    Thanks CJ. They just dont understand...
    Not the best suspension? If you could, please explain what is the best? Last time I checked, this setup won the STS championship....
    The car has pretty much a stock motor but its all in the suspension. I'll put it this way, the car runs away from vettes at auto-x's and Road Atlanta.
    The car has the PERFECT setup IMO. I can also give my setup book and other info about that to the buyer.
    Lots of spares!!!
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    Newnan
    congrats to you, wasn't trying to knock just stating my opinion, apperently im wrong if you pull on vette's in the corners.
    WILL NOT PART OUT!
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    All Motor EK N/A EK's Avatar
    On IA.com
    reps
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    didnt i see this car spin out on the parade lap at little Talladega?
    Hamilton, GA
    this car sounds sick and you don't have to have alot of power for autocross
    cravin a s2k
    Cookeville, Tennessee, United States
    koni/GC>D2's any day.
    still for sale...
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    ALL CAPS JITB's Avatar
    U
    NEED
    BETTER PICS
    You have a million parts, and 3 pictures
    bump bump. car has to go ASAP
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    Someone coming to look at the car tomorrow...
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    Atlanta, Ga
    This is a well loved car that's been used for it's intended purpose...to be run ****in hard...the way every honda should be. I've seen it in person, and this guy doesn't mess around.
    Good luck man!
    CAR IS SOLD!!!!!!!
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    How much did you get for it??
    $1100. Looks like HFMS has the last real race cars left on IA.
    $5000. Going to a good home in Virginia. Autocross guy.
    $5000. I suck a fat one
    FIXED
    the new car is coming soon. will post the pictures when i get it
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
