Results 1 to 10 of 10
Thread: Another LS VTEC question
    Cobb County
    Default Another LS VTEC question
    What's the best STOCK rods to use in a LS/VTEC?
    Planned Setup:
    B18B1 Block
    B16 Head
    PR3 Pistons
    Southside
    You can use LS, but mostly everyone else leans towards Eagle
    your moms house
    stock rods with arp bolts but aftermarket rods would be best
    Around metro-ATLANTA & IA!!
    i got B18a/b ARP rod bolts for sale, ARP rod bolts For LS, IGN. COIL, Voltage Stabilizer thingy
    YEAH! bRiAnMcIvIcS's Avatar
    Eagle rods and arp rod bolts.
    the only rods that will work with an ls crank are b16 b17 and ls. b16 nor the b17 will work because they are both to short. the problem with stock ls rods is they wont hold up under the load. u have a better chance with arp bolts but still running a risk. normally i use aftermarket rods and arp bolts if the aftermarket rods doesnt come with them.
    get your LS rods shot peened
    Quote Originally Posted by Gilgamesh
    y. do the reseach on them then say that again.
    Integra KA98S10's Avatar
    I had eagle rods and arp bolts.. That combo worked well!
    Out in the Boonies
    I've found that they are shotpeened from the factory.
