Results 1 to 23 of 23
Thread: MPG question
    IA's culinary pro TheGrillMan's Avatar
    Default MPG question
    so im making my way back to florida tomorow. i was wondering what would i be better off doing as far as gas is concernd
    should i go at a higher rate(80-90) for a shortewr amount of time (takes less time to get there at a higher speed)
    or
    go slower at less of a rpm and take more time?
    whatever would yeild better mpg is what im looking for
    any intelligent anwsers will be rewarded
    Oct 2003
    Typically, you want to cruise around the fat of your tq peak. The reason for that is because it takes less effort to move the vehicle at the same pace. My tq peak starts around 3k rpm, which for me is around 60mph so when I cruise, I typically cruise around 60-65 mph. On the same token, the higher your RPM's are, the more fuel you're going to burn due to the fact that at higher RPM's the computer is gonna add more fuel to keep it from overheating from "leaning out". I hope that gave you your answer.
    Patience Pays...
    55mph, if you have a manual shift before hitting 4k rpms
    Senior Member Schugg's Avatar
    dont just worry about how you drive, check you tire pressure, air filter, if you werent leaving tomorrow ide say do a full sea foam treatment. (depending on how old many miles you have) but you can just do a quick one of adding a can of sea foam to a full tank of gas, and clean your injectors out with some sea foam deep creep. but when you have time i highly recommend doing a full sea foam treatment. if your interested here is a good guide.
    http://www.ls1tech.com/forums/showthread.php?t=534376
    just dont do it from the hose directly on the brake boost like that says, do it after the little plastic separator/deregulator(?) or whatever the piece is that separates the 2 hoses between the brake booster and IM
    that wont help you so much for tomorrow but will in the long run.
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    i found that if i cruise at 55-60 i get good mileage. an if i dont give a shit about how long its going to take me to get there i coast down hills and let the momentum if theres enough carry me back up hill.
    ok thanks guys i think blackshine anwserd my question pretty well
    but another question, you said at the fat of my tq? is that where i get into my powerban or when im getting out of it, i knwo it;s prob the first i stated hah
    also it;s an auto 1.6l if that helps any
    i go up to virginia every week and i drive 80 miles with cruise control on in a 1995 civic dx and i get beter gas milage then me manually pressing the gas.
    Quote Originally Posted by jdmb16killa
    well yeah CC is more consistant
    80mph?
    i drove 80-90mpg from atlanta to dallas and got great gas miles in comparison to what i normally get. but in the end you just have to think what matters more to you. the 30 mins to an hour you may gain by going faster, or the few dollars you may save going slower
    - 2008 Acura TL-S
    Oct 2003
    Quote Originally Posted by TheGrillMan
    Notice on my dyno where my tq starts? notice where it starts to fall off? The more available tq the better gas mileage you will get.
    Attached Thumbnails Attached Thumbnails -ia-dyno-jpg
    i see no graph
    also the car im riding is a BG chasis protege
    Oct 2003
    i see no graph
    DO you have the B8 or the BP? And are you a member of clubprotege? I too have a BG protege.
    02 WRX patrick4588's Avatar
    warner robins
    which is more important to you? an hour or 5 dollars? to me, an hour is more important. i would travel about 85-90 and not worry too much about the mpg
    GCO Member
    NRA Member
    Oct 2003
    I bet you have a bunch of tickets, don't you? I'd rather cruise somewhere near the posted speed than to get busted for doing over the limit anyday of the week.
    80-90 is the "unposted" speed limit for big interstates/highways. everytime i travel if im not going around those speeds im getting passed all over the place.
    - 2008 Acura TL-S
    Super Handling
    As an honest answer. Drive at night. Less traffic and temperatures would be cooler for a more efficient engine. You'd probably wouldn't need A/C either. Everytime I visit my brother in South Carolina, I drive at night.
    im thing it;s the b8, i know it;s an lx and has the 1.6l dohc in it
    and yeah im member hah just never ever post
    warner robins
    i got my fair share of tickets, but that was when i was younger, ive only had 1 in the last year and that was on a recently changed speed limit road. ive never had one on the interstate. doing 85-90 on the interstate is about the norm. drive 70 and get ran the **** over.
    GCO Member
    NRA Member
    Oct 2003
    If you have a BG, it's gonna come with either the 1.8L SOHC (B8) or the 1.8L DOHC (BP). Being that you said you have an LX it's gonna be the BP. I made a thread about me gaining fuel mileage. Do a search on my name in that forum under fuel economy and my sig in here will explain everything.
    IA Member jbhondatech's Avatar
    every 10mph over 60mph = a 4% reduction in fuel economy due to air resistance in the front and the vaccume effect in the rear. This is why racecars draft each other. Playing with your ignition timing can also increase fuel economy at certin rpms but reduce it in others this trick is realy only good for highway driving
    Turbo-Wired
    East Cobb
    Quote Originally Posted by jbhondatech
    More information on drag coefficients and such.
    Realistically, the more important factor is how deep your foot is into the pedal through the course of the trip and how often you spend accelerating. If you want the best idea for saving gas: Get behind a big 18-wheeler, RV, or bus and shadow it. When you lose it and it turns off, find another. Oh, and try and drive at night, but make sure to get plenty of sleep and be well rested!
    Senior Member BlueHatch's Avatar
    Green Acres
    just tuck in behind a suv and draft him. i got 33 mpg in a mildly built 4.6 mustang tucked behind an expedition
    Totalled my baby :(
    Columbus, Georgia
    When you get to coasting down a hill for a good half a mile or so, put the car in neutral and just coast along. Not the most effective thing in the world, just an extra tip.
    - GAplayboi
