Results 1 to 19 of 19
Thread: b16a swap wont crank
    Certified Gearhead dirty5outhaz's Avatar
    Jackson, Georgia, United States
    Default b16a swap wont crank
    i just put b16a in my 94 coupe. simple swap done a million times. well i used my old wire harness, old ecu, and injectors. it turns over but wont fire up. i was getting spark and a fuel but wasnt sure if it was getting enough. so i changed the injectors. still nothing. buddy of mine said that it could have been my distributor, so i got another used one. and it still doesnt wont to crank. please if anybody knows what the hell is up with my car please lmk.
    do u got compression. is your firring order right. when u test for stark if u go about an 3/4-1" away from ground does it arc. do u have oil presser.
    college park
    its your dizzy mine did the same thing if its doing this this is my vid from my swap
    http://www.youtube.com/watch?v=n8F2-Detc2A
    turns out it was loose wires near the dizzy so recheck your wires as well as the ones at the ecu
    now with LSD
    check the ground wire on the t-stat housing
    yeah mine is doing the exact same thing. which wires are you refering to?
    ice sex tornado
    griffin
    your plug wires man
    vtackinn
    Quote Originally Posted by scrxils
    your plug wires man
    what would be wrong with my plug wires?
    my check engine light is on if that helps.
    well whats the code
    check the firing order....1-4-3-2 ....also how do you know its getting fuel an fire? I bet you got a bad main relay ..if you take it out an bring it to me ill fix an can inspect it for bad soldier spots/cracks
    firing order is good. as far as fuel goes i pulled the fuel rail out with the injectors still in the rail and got someone to turn the key and all of the injectors are working. someone told me that if the main relay was bad my fuel pump wouldnt be working.
    well whats the code
    how do i get the code?
    L'ville
    check the ground to thermostat housing
    Quote Originally Posted by dirty5outhaz
    ***The Big FAQ Thread- Honda/Acura, ECU codes, Swap Info, Wiring. READ FIRST***
    scroll down to u get to
    HOW TO CHECK ECU CODES OBD1 and OBD2 Honda/Acura
    Quote Originally Posted by stygiosracing
    checked it. its good
    check timing...migh be off couple of teeths....just an opinion...!
    u going to say what the code is.
    L'ville
    it might be your flex capacitor.... or your firing order..... or your timing..... got compression?
    Hamilton, GA
    i would say firing order, main relay, engine grounds and figure out what code it's throwing
