Results 1 to 11 of 11
Thread: CAN ?
    boricua chrisdohck's Avatar
    Default CAN ?
    Hey im new to the turbo club but i had someone tell me something and i was wondering if it was true ....ne way will mazda Rx7 injectors work on a boosted civic?
    Don Mon SiRed94's Avatar
    Morrow 30260
    Pm'd
    Total Insanity helcat17's Avatar
    macon
    hmm i kinda wana know that too i run dsm's
    yes they will
    a lot of different type of injectors will work in a honda. first, make sure you get top feed injectors and not side feed. second, use a digital multi-meter and check the resistance of the injectors...2-4 ohm=use resistor box...11-14 ohm=don't use resistor box. what ever car you get the injectors out of, try and get the injector clips too...that way you won't have to chase down a set if your stock clips don't fit or can't be modified easily.
    hope that helps.
    Yea there is set of older rx7 injectors that are like 560cc that will fit with some modification to the o-rings
    Hiram/Dallas area
    non turbo rx-7 injectors, 460cc.
    turbo injectors, 550cc.
    all 13B and 13BT motors had top feed injectors. 1st generation (84 and 85 only) GSL-SE had a 13b with fuel injection and a distributor, all 2nd generation (86-91) had a 13b (or 13bt for the turbos, 87-91), but with a direct fire ignition.
    3rd generation RX7, USDM, 93-95, had "side-feed" injectors, BLEH.
    non turbo, 86-87.5 model years have low impedance injectors, they have a center grooved injector/clip.
    87.5-91 models years are high impedance, they have an offset groove clip.
    they should also have like an orange-ish color top.
    these are all over my shop, i was thinking about using them if i boosted my Daily driver (sohc civic), but then it wouldnt be as economical (38-40+ Mpgs)
    Ive got a boosted sohc and i get between 32-36mpg depending on what kinda driving i do
    my boosted sohc gives me consistent 36mpg...half/half highway/city.
    yes the injectors worked thanx scotty for the base map hope fully i can get it tuned some time soon
    Morrow 30260
    Quote Originally Posted by chrisdohck
    I can't wait to rape you with an all-motor 12valve SOHC...
