Thread: Integra rev problem
    95 teggy for parts DaRussian's Avatar
    Default Integra rev problem
    Hi i have a 94 integra ls and whenever i drive the rmps jerk up and down, what could be the problem
    VQ Power ------- SHIFT_W.O.T <br>
    03 Maxima 6spd VLSD -- 1/4 mile -- 14.12 @ 96.3
    92 eg Hatch b20vtec -- 1/4 mile -- 13.6
    Originally Posted by MMBmomoney
    i changed the vtec solenoid and nothing changed. in another post i saw "vtec fluid" where is that located and how do i check it?
    Duluth, G-nett
    does the car jerk or just the rpm? could be the speed sensor.
    fast idle valve maybe
    iacv,tps,map.
    turbos
    ^^^^where is your avatar
    iacv,tps,map.
    TOO BIG
    brought down by the man :/
    Mad Scientist xb1's Avatar
    Athens, Ga
    I'd check those sensors in the following order (which assumes that you'll be swapping them for ones that you know will work): MAP, IACV, TPS. The TPS is part of the throttle body, so you'll have to swap the whole thing out to test it, which is why I'd do it last. You may want to first try to ziptie the MAP sensor plug to the sensor (add a drop of superglue on the corners opposite the plug, but just a drop, so the ziptie does come right back off).
    thanks guys i got it, my distributor was loose lol. sounds so stupid but i opened my hood today and first thing i checked to see if the distributor cap was clean inside, but it was loose and the whole distributor was wobbling lol, the car been standing at the shop for months so somebody must have loosened it
