Thread: need help hub bearings
    Exclamation need help hub bearings
    has anyone on here put new hub bearing on your car if so i need to know if you need to get them pressed or it is able to do with out doin that?
    pressed
    It's easier to get it press out. You can do it without the press, but it takes awhile. Lots of beating on the new bearing which can mess it up. Press it out and press it in.
    ok well i guess i will have to go get some one to do it
    JDM TYTE AnthonyF's Avatar
    MOST hub bearings are pressed. Take it to a professional.
    -Ant.
    The Carbon Fibered R6
    ooo fyi if u your the shop u take it does it wrong u will need a new spindle. ive seen it done wrong at a few shops ive at and every time the spindle gets bent. just a heads up.
