Results 1 to 4 of 4
Thread: Q about a Mitsubishi turbo???
    Senior Member | IA Veteran Mad Mike's Avatar
    Gainesville
    Default Q about a Mitsubishi turbo???
    I have a turbo in good shape off a 88 dodge conquest.mitsubishi starion. Its a TD05 12A I belive.
    My Q is are all the TD05 manifold flanges the same?
    I'm looking at building a turbo kit for my D16Z6 swaped crx and this turbo is just sittin in my garage. I'm going to use a CX or std manifold off a civic and make a adapter plate between the manifold and turbo exhaust inlet. Unless the flanges are the same and I might buy a TD05 manifold.
    Or buy a complete kit.
    I'm just looking at difforent options.
    thanks for the help
    Gainesville
    anyone know???
    Gainesville
    Well I got some confirmation on the TD05 flanges being the same so I picked up the TD05 turbo off a conquest for free today. Turbo is 100% perfict, no shaft play and no leaks. So far only problem seams to be the turbo sits ontop of the manifold so the oil out line is facing up. May have to convert it to external wastgate so I can spin the exhaust housing to make it sit right or get a top mount manifold made or modify one to work. Hmmm ether way the turbo was free so if it don't work so what.
    Also got the stock down pipe but not sure if I madify it and use it or get one made yet.
    you can turn the housing so your drain hole can be facing down instead of up.
