Thread: dizzy question
    keep D series alive SLPR's Avatar
    with ya gurl
    Default dizzy question
    will my 89 crx si dizzy fit on a obd0 dohc zc motor??
    i kno the dizzy cap and rotor will, but not sure bout the dizzy itself.
    i have a wiring adapter from rywire.com that converts the 7pin to a 5pin connecter.
    thanx in advance and reps will be givin
    Southside of The Jungle
    Yea you gotta get the adapter.I see you have that try it make sure the part that goes in the cam is faced the right way.Because if it wont go all the way in rotate it all the way around to the other side should fit right in.
    with ya gurl
    thx man. ill give it a shot when i pick up the motor
    with ya gurl
    can anyone second this?
    Your moms house
    Second what? Don't force the dizzy in, if it won't fit rotate the distributer shaft 180 degrees and then insall.
    with ya gurl
    Quote Originally Posted by 1flysi
    Second what? Don't force the dizzy in, if it won't fit rotate the distributor shaft 180 degrees and then insall.
    i kno that much...im askin can anyone agree that the crx si dizzy will work on a obd0 dohc zc motor or not
    Your moms house
    Yes, I have used a crx dizzy on a dohc zc.
    with ya gurl
    ok i just wanted to update this.
    i tried my d16a6 dizzy on my DOHC ZC(D16a1) and it doesnt work.
    the connectors all hook up using my adapter from rywire.com, but the bolt patterns are wayyyy off.
    that sucks...now i gotta buy a 88-89 teg dizzy and im broke.
